Page 1 of 2 12 LastLast
Results 1 to 20 of 35
    Owner of a SupeRioR
    Sharkey R's Avatar
    Apr 2012
    Newbury, Berkshire
    186
    Coolant Level Low - New Coolant Tank and Sensor
    Ok guys I have a slight issue with the R. Since changing the Coolant Expansion Tank from a brown stained tank to a brand new tank I've had a coolant low warning light on the dashboard. It was decided that the sensor might have been damaged when removing from the old tank and refitting in the new tank so that was changed. Still got the same message on the dashboard. Jamie at PFS was kind enough to send me out another tank as we figured that it might have been a faulty float. Just changed the tank again and I've still got the same warning. Out of curiosity I tried pushing the float down and this briefly turned the light off but then a few seconds later it comes back on.
    Any ideas?
    Doing my bit for the environment by driving a 'Green' car!
    Randomly Typed Username
    Iraq Lobster
    jamesy12345's Avatar
    May 2013
    lives on Standard Row
    4,606
    Genuine or aftermarket tank? Wiring OK?
    Owner of a SupeRioR
    Sharkey R's Avatar
    Apr 2012
    Newbury, Berkshire
    186
    Quote Originally Posted by jamesy12345 View Post
    Aftermarket tank, tried 2 tanks and both do the same thing. Yeah the wiring seems fine. It's all clean and there's no kinks or anything in it.
    Iraq Lobster
    May 2013
    4,606
    Quote Originally Posted by Sharkey R View Post
    Pull the sensor plug out of the socket - light should go off. Bridge the connections - light should go on. If that works the wiring is probably OK......
  5. #5
    Owner of a SupeRioR
    Sharkey R's Avatar
    Apr 2012
    Newbury, Berkshire
    186
    The light stayed on when it was unplugged.
  6. #6
    Owner of a SupeRioR
    Sharkey R's Avatar
    Apr 2012
    Newbury, Berkshire
    186
    The bit I don't get is why would the light go out when you push the float down to the bottom of the tank and then as the float rises back up the light comes back on?
  7. #7
    Iraq Lobster
    May 2013
    4,606
    That's odd - looking at the wiring diagrams the float completes the circuit, so unplugged sensor should be open circuit & no light...any break in the wiring could send 12v to earth though that's what I was thinking.
    See page 85
    http://www.volvowiringdiagrams.com/v...20Diagrams.pdf
    sensor component number is 7/73
  8. #8
    Owner of a SupeRioR
    Sharkey R's Avatar
    Apr 2012
    Newbury, Berkshire
    186
    I'm rubbish when it comes to electrics so I think I'll pop it in to the specialist I use and see what he can find. Just seems weird it all started when I changed the tank.
  9. #9
    Member
    Jul 2013
    Haarlem, Netherlands
    0
    Change back to the old tank and see if that helps?
  10. #10
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Do you still have the old tank tape up holes then plug it in then fill it up to the line does the fault lamp stay off.
    Could be a bad batch of tanks sensors !
  11. The Following 2 Users Say Thank You to Harvey For This Useful Post:
    jamesy12345 (Sunday 20th July 2014),merc85 (Sunday 20th July 2014)
  12. #11
    Owner of a SupeRioR
    Sharkey R's Avatar
    Apr 2012
    Newbury, Berkshire
    186
    Unfortunately I didn't keep the old tank
  13. #12
    Owner of a SupeRioR
    Sharkey R's Avatar
    Apr 2012
    Newbury, Berkshire
    186
    I've just bridged the socket for the coolant level sensor switch and the light goes out. Does that mean the sensor is giving a wrong signal?
  14. #13
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    I bridged the connector last week, and the light went out, so the wiring's fine, I think I still have your old tank Steve.
  15. The Following User Says Thank You to stribo For This Useful Post:
    jamesy12345 (Monday 21st July 2014)
  16. #14
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Just wondered what sort of warranty is given for the work done.
  17. #15
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Warranty doesn't come into effect until the bill's paid. Also it's a part that's faulty, not my work.
  18. #16
    Driving Miss Daisy
    V70 Graham's Avatar
    Feb 2012
    West London
    2,909
    I'm glad I didn't go now, my tea would have been to blame no doubt.
  19. #17
    Iraq Lobster
    May 2013
    4,606
    I better get out & try mine but sounds like it's opposite from what I said above....maybe pointing at the car doesn't like the aftermarket tanks?? It would be unlucky to have 2 bad sensors
  20. #18
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Quote Originally Posted by V70 Graham View Post
    The way you make tea, yes.
  21. #19
    Owner of a SupeRioR
    Sharkey R's Avatar
    Apr 2012
    Newbury, Berkshire
    186
    Cheers for the input guys. Think I'm tempted to try a genuine sensor first, the float seems to move freely in the tank so I can't imagine its that. I'm away all week with work so I'll try it on Saturday.
  22. #20
    Driving Miss Daisy
    V70 Graham's Avatar
    Feb 2012
    West London
    2,909
    Another R to be broken....
  23. The Following User Says Thank You to V70 Graham For This Useful Post:
