Page 2 of 9 FirstFirst 1234 ... LastLast
Results 21 to 40 of 170
  1. #21
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,548
    Some say the closer to the throttle the better but I know of a few people running their BOV on the OTE pipe with no problems at all.
    Down to personal preference I suppose. The air in the throttle pipe is gonna be cooler than the air in the OTE pipe so might be better for the BOV to keep the hot stuff away.
    310.2bhp / 333ft/lb
    SOLD
    Got an old discovery now.
  2. #22
    Jul 2008
    126
    Thinking about it I agree about the throttle pipe and air temps, also the IAT sensor is downstream of the said pipe, it makes sense to recirc air that has just been measured, rather than vice versa.
  3. #23
    Jul 2011
    Poole, Dorset
    6,548
    errr.... yeah, that too
    310.2bhp / 333ft/lb
    SOLD
  4. #24
    Jul 2008
    126
    Then again, it seems good enough for IPD. Too many choices!!!!
  5. #25
    Jul 2011
    Poole, Dorset
    6,548
    Let time and money guide you and do whatever is cheapest
    310.2bhp / 333ft/lb
    SOLD
  6. #26
    Trader
    Ready for the weekend
    partsforvolvos.com's Avatar
    Jun 2012
    Rainy Wellingborough
    270
    I thought it was closest to the throttle body to keep the air moving in the same direction up toward the intake.
    if you fit the valve mid way along, the air coming out of the turbo toward the valve is ok, but the air that has already past the valve could flow backwards defeating the object of keeping the turbo free wheeling.
    obviously an engine requires intake air to idle off throttle, but its only a fraction of full flow.
    for the same reason having a recirc valve on the turbo is ok because it prevents the stalling and can freewheel.
    it comes down to available space sometimes hence the do88 lower pipe not being able to be used with the original airbox and probably the same reason for the ipd pipe having it on the ote.
  7. #27
    Ghost Rider
    If I want your opinion, I'll
    ask you to fill out the
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    My bov is mounted on the turbo to intercooler pipe, it runs and boosts perfectly ok .
    For a bit of bed time ready look up my thread "pros and cons of dumping hot air"
  8. #28
    Jul 2008
    126
    I only want to-do it once, hence wanting something welded. I guess the OTE will be the easiest.
    The do88 pipe, I can't understand it, 38mm outlet when their BOV is 25mm. I guess you don't have to weld the bung so it's in the way of the airbox snorkel, but I guess this was only an issue with the R style airbox, hense why do88's is like that.
    Thank guys.
  9. #29
    Jul 2008
    126
    OK so I'm going for a custom throttle pipe with bov outlet, courtesy of Graeme.
    Thanks for the input guys.
  10. #30
    Jul 2008
    126
    UPDATE time
    New mods:
    Cavalli - 'drop-in' Turbo CTB30VR
    GWE - Custom 3" ETM Pipe with the relevant connections for WI and RECIRC valves, powder coated black
    GWE - Custom 3" Turbo Inlet pipe
    Turbo Smart RECIRC/BOV piston operated valve.
    It's running and pulled like a train and popped a hose, after some surgery everything seems ok but we noted it had also blown a CV boot, so another thing to-do, tomorrow!
    Once everything is 100% the tuning will start, but I'll be limited by the stock clutch at present.
    Turbo - sounds like a bus turbo, weird super charger noise at low RPM, I'll get used to it, no real data yet until the mechanics are 100% but it seems to spool at around 3k then almost instantly be at 1.5 bar.
    Thanks to Graeme and Shem for their help. (UNDERSTATEMENT)
    There were a LOT of fitting issues (drop in part needs work for VBAND users) , but hats of to the supplier for making it right so far, at present the OTE doesn't fit very well but that is being replaced.
    Next is clutch, has to be I think.
    Full spec for the sake of completeness:
    Shimmed 2.5l block
    New cambelt
    47k miles
    ipd ARBS
    Stainless brake lines
    New stock Volvo pads and discs
    Mehle droplinks and top hats
    Prosport boost gauge in CF pillar mount
    3" DP with 200 CPI magnaflow cat
    feritta Catback
    17" pegs with a full size spare.
    RTI, Phone (££££e)
    Volvo Bluetooth
    reversing cam
    shem strut mod
    Poly wishbones
    Rear digital TV and dvd etc
    45mm klracing IC
    AEM progressive water injection
    750cc injectors
    GWE - Custom 3" ETM Pipe with the relevant connections for WI and RECIRC valves, powder coated in black
    GWE - Custom 3" Turbo Inlet pipe.
    Oil, Plugs, Filters, etc.
    Turbosmart dual bov with trumpet removed.
    Black silicone!
    Angle gear has been out and collar looks good.
    TODO
    Clutch upgrade.
    Many many map revisions.
    Uprated oem tcv (new pierburg oem design).
    cv boot.
    Fix some broke interior plastics.
    good clean!
    RS4 maf with custom airbox adapter.
    Snabb OTE pipe and adapters (might powder coat this first).
    Maybe a 3" custom zorst system.
    GWE did the custom stainless piping (powder coated black), and omg, it's a work of art!
  11. The Following User Says Thank You to Dream3r For This Useful Post:
    M-R-P (Thursday 30th October 2014)
  12. #31
    Jul 2011
    Poole, Dorset
    6,548
    Nice to see an update mate.
    Those 200 cell pipes are lovely
    310.2bhp / 333ft/lb
    SOLD
  13. The Following User Says Thank You to M-R-P For This Useful Post:
    Dream3r (Thursday 30th October 2014)
  14. #32
    Shiny Superstar
    Back in the game!
    Wobbly Dave's Avatar
    Aug 2004
    Stunning Shropshire
    2,501
    how you doing the recirc?
    Volvo ABS ECU Repair
  15. #33
    Jul 2008
    126
    Intercooler Outlet to 3" ETM PIPE, recirc boss on the 3" pipe, post ETM, sent back to the intake, post MAF.
    Seemed like the best place to put it to me.
  16. #34
    Jul 2011
    Poole, Dorset
    6,548
    Quote Originally Posted by Dream3r View Post
    As long as you can get it to bark and chirp, you're on to a winner
    I'm not a chav..
    Honest
    310.2bhp / 333ft/lb
    SOLD
  17. #35
    Jul 2008
    126
    It's oddly completely silent, more so than stock!
    I've still got some playing/setting to-do with it. I can also stick on the trumpet and give the maccyD crew something to talk about, whilst over-fueling
    Turbo sounds like a jet turbine though.
  18. #36
    Jul 2008
    126
    GWE's handy work
  19. #37
    Jul 2011
    Poole, Dorset
    6,548
    Looks busy in there John, you sure you know how it all goes back in?
    I remember Graeme developing those pipes (and the language he used to describe the process lol). Tidy work that.
    310.2bhp / 333ft/lb
    SOLD
  20. #38
    Jul 2008
    126
    That was GWE's fitting of the pipe, his pic. I'm comfortable around there now, but that's it, lol.
    I'm going to be mapping and adjusting my BOV now, much work ahead, possibly months until I'm happy.
  21. #39
    Jul 2008
    126
    Map v2 (5 bar Cavalli)
    Silly maf readings, past stock limits, but still reading suggesting 400-420 bhp
    Loads of work to-do still it's pretty raw the boost control, the turbo seems capable of 1.6 bar at just over 3k.
  22. #40
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Will be watching with interest, hope I didn't get you in trouble earlier.
