Results 1 to 8 of 8
    Member
    Nov 2011
    0
    '03 V70 R AWD MoT fail - Near side front headlamp too low!
    Hello VPCUK - my 03 V70 R AWD (see my garage) failed MoT on the above technicality - any ideas/advice etc? Thank you in advance!
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    As they're self levelling it would be worth checking to ser if the motor is working in that headlight. As a temporary bodge, there is a certain amount of manual adjustment on the light unit, there's a 7mm (I think) white plastic but on top of the light that you can adjust it with.
    Member
    Nov 2011
    0
    Hi Stribo - thank you. I will take a look and see but my trusted Volvo specialist (Watchfield Service Station aka Swindon Volvo) couldn't adjust manually enough themselves so I am booked into a main dealer for Friday (who was rude about older cars!!)
    Owner of a SupeRioR
    Sharkey R's Avatar
    Apr 2012
    Newbury, Berkshire
    186
    The suspension and headlights have a Sum Calibration. I'm sure someone else will confirm but I'm led to believe that before they are calibrated they will be manually wound down to a lower setting so that once they are calibrated to the correct height you'll be able to manually adjust them higher again if needed. I had no adjustment left in one of mine and they were recently done and I now have more adjustment.
    Doing my bit for the environment by driving a 'Green' car!
  5. #5
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Just to ask the bulb is correctly fitted in the headlight unit ?.
  6. #6
    Driving Miss Daisy
    V70 Graham's Avatar
    Feb 2012
    West London
    2,909
    Good point, a guy at my work did this recently.
  7. #7
    No replacement for
    displacement!
    Redbrick's Avatar
    Mar 2005
    Bristol
    35
    I have the Bi-zenons on my V70, exactly the same as the R units other than the internals are black not silver.
    The bulb can be put in incorrectly as I have managed to do this. The best way to do it for me with big hands is to take the light unit out, I appreciate that is a PITA but I've put access holes for the light unit side bolt in my bumper carriers.
    As stated there is a special way of recalibrating the lights on an R once all four wheels have left the ground say for shock changes. I think this is only through VIDA.
    Mine can be adjusted like normal light units as I don't have 4C.
    If the bulb has been changed recently my money would be on it not having been fitted correctly.
  8. #8
    Member
    Nov 2011
    0
    Hello All - unfortunately for me, the adjustment unit needs replacing so I'm in for £180 of new unit at the main dealer Monday time. The bulbs and their placements are all good - it's just that the teeth on the adjustment unit seems not to be meshing. She's needed for next week so I plan to JFDI here. Thanks for all the help as I was really hoping it would be a quick and easy fix!
