Your a pathetic lil man
JamesT5 (Sunday 29th June 2014),T5RatherAmusin (Saturday 28th June 2014)
come on guys keep it clean, give me 3 makes of intake and were to get them from.
Then you can do what you want lol
Pfv will do you the do88 stuff
Theres the snabb and ipd stuff over usa....
v70 b5244t5
a 3" intake wrecked my forged engine as for one i didnt turn the boost right down before i drove it, then build it up again, only drove a mile before it went pop
lots of missed views on them it seems.
suppose I will have to keep a close on the afr for a while if I do fit one
MoleT-5R (Saturday 28th June 2014),p fandango (Saturday 28th June 2014)
Well your wrong as well!........it does amaze me how so many members slag off one person for there thoughts on helping another member and then you answer a load of rubbish but your friends say nothing!.........what a load of crap members you all are clicky...clicky...clicky........i am so glad i don`t go to meets to waste my time and fuel meeting you all, your`e simply not worth it!
The ribs do not slow any airflow up in fact they can tumble the air so the air vanes in the turbo`s compressor can grab the air better as it it tumbling instead of straightforward hitting.......the ribs are mainly there for flexibility of the hose for engine movement......although the larger hose will encourage faster airflow it`s volume is not increased as it has to get by the MAF which is smaller in diameter so therefore the AFR`s will be similar as the MAF reads the same volume of air and if out the ECU will compensate but only to a limit.
It seems Frankie went over the limit due to a 3" MAF without a remap....
Think again!
So Frankie you knocked the nail on the head.............It`s the lack of knowledge that causes these failures with rods etc.......just as you have just said.......other members included...
.........and as for a quicker TCV than an OEM one what utter crap from a member that belongs to a motoring organisation........i for one am glad i ain`t a member.....it is the ECU that is slow.......and yes, i do know about ipd problems
Mercedes C320CDI Sport Estate 3 litre V6 7 Gear Auto
Remap 290bhp 628Nm torque @ 1600revs 45.1mpg
960KG strikes again. Hello mate how are you doing?? lol
PIC][/SIGPIC]
aaaaaaaaaaaaaaaaaaaaaaaaa
Try Graeme Welsh on this forum. He made them and may have some left
Ex Police V70 T5 SE now scrapped.
Daily driver V60 D3 R-design
2004 C70 2.4T GT, modifications front strut brace, 19" Peg reps with white lettered tires.
Let's assume I'm a complete moron (shouldn't be difficult ). Can anyone explain to me:
1) How does a larger bore intake make the air flow (gas speed) faster?
2) How does a larger bore intake increase air flow (gas volume) if the turbo remains the constant in the equation?
3) How does a larger bore intake increase boost pressure, or make the turbo boost past the normal limit, when it's on the unpressurised side of the turbo?
2001 V70 T5 (Manual) - The Turnip
1999 9-5 Aero (Manual) - Sven
960kg knows everything but until he coments,
1) the increase is because the larger intake walls are smoother so its easier for the air to flow (try tumbling as apossed to runing) which is quicker?
2) the increase is less work on the turbo as its able to spoolfaster as its able to flow quicker to due to the above
3) Boost pressure is increased slightly as the turbo is not having to work as hard, flowing smoother with slightly more volume due to the islight ncrease in size of piping
Thats how i understand it anyway lol, Andys car boosted more with the Larger intake over the standard ribbed version hence the Bent rod.
Just to ask what is the smallest dia of the stock pipe is it smaller than the dia of the air flow MAF body ?.
My thoughts on this are,from the turbo to the air filter inlet pipe the system will be under vacuum with engine running.
So if your were to fit a ram air inlet pipe the level of vacuum would be less.
So the people that fit a air filer onto the MAF will have a lower vacuum at that point as there's no box for the filler or cold air inlet to that point that the air has to be pulled through.
So from the MAF to the turbo inlet flange there's always a vacuum there ,so if the MAF dia is larger than the dia of the turbo inlet flange,but the stock pipe is smaller than the MAF or the flange on the turbo ,fitting a pipe which would be the same size as the MAF would lower the vacuum level up to the point you get the the turbo inlet flange.
But the main point as I see it is the turbo inlet side is having to suck air through it,so if you can reduce the level of vacuum present by cutting down the drag on the air upto the turbo it will move more freely than it would otherwise do so.
merc85 (Sunday 29th June 2014)
yes bud the stock pipe narrows quite abit just before the turbo where as the replacement doesn't
i wrecked my engine due to not compensating for the extra boost by fitting a 3" maf by simply turning it down, had i done that before driving it would have been ok
