Got yet another issue now.
Was driving along and I got a warning message on the dash: "BRAKE FAILURE STOP SAFELY". In addition, the tacho, speedo and water temperature gauges all stopped working. T1 reset to a series of dashes and it wouldn't alternate between T1 and T2 if you pressed the trip reset button. The ABS and handbrake warning lights also came on.
I pulled over and switched off and back on again (the brakes still worked incidentally) and everything went back to normal. However, as soon as I pulled away, it did exactly the same thing again. I drove on for a short distance and the car drove normally with no problems with the brakes, but the dash was still the same. I pulled into a car park and switched off again. Everything returned to normal as before. I drove round the car park a bit and this time the dash stayed as normal with everything working fine again. I've since driven another few miles and everything has stayed normal.
Any thoughts?
