Page 1 of 2 12 LastLast
Results 1 to 20 of 28
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Intake pipe fitted.
    Got around to fitting the intake pipe to the R today. It's a GWE one and although no-one would argue that his welding is top drawer, his finishing, and attention to detail leaves a lot to be desired though, as the metal pipe still had swarf in it:
    Not really what you want to be sending through the engine, the pipe for my C70 has even more in it.
    So, to fitting, getting the old one off was a piece of cake, with a couple of extensions and a wobble bit I could get to the jubilee clip holding the pipe to the turbo from the top, then it was just a case of pulling the PCV and vac hoses off it, seperate it from the MAF, and done. Putting the new one on was a bit more fiddly, but I put it on in stages to make access easier, and an hour later it was all back together.
    Took it for a quick spin and there's a bit more turbo noise, which is nice, and although I don't know if ultimately any quicker, it certainly sounds more angry. All in all very happy.
  2. The Following 2 Users Say Thank You to stribo For This Useful Post:
    AndysR (Saturday 31st May 2014),M-R-P (Saturday 31st May 2014)
  3. #2
    Jul 2008
    2,869
    It's amazing how much sound is deadened in the standard corrugated intake pipe isn't it!
    Gun Metal Grey - Volvo 850R - Saloon
    Thanks to Russ and team www.rtmechanics.co.uk
  4. #3
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Quote Originally Posted by AndysR View Post
    Yeah, I think the metal section helps amplify the sound.
  5. The Following User Says Thank You to stribo For This Useful Post:
  6. #4
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,548
    Nice writeup Steve.
    The combination of dp and metal intake certainly makes for some satisfying noises.
    you should borrow my recirc gizmo sometime chirp chirp
    310.2bhp / 333ft/lb
    SOLD
    Got an old discovery now.
  7. #5
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Nice writeup Steve.
    I would, but I'm not a chav. TBH I like the sound of the recirc, the K24 one sounds a lot different to the 16t one, a lot more urgent.
  8. #6
    Jul 2011
    Poole, Dorset
    6,548
    The k24 is an internal piston type and has a sharper sound as a result.
    with the recirc locked off, a 17psi gearchange gives of one almighty chirp rather than chattering. Very satisfying but the chatter gets irritating after a while, hence I have a switch to turn the bugger off when not being a chav lol.
    310.2bhp / 333ft/lb
    SOLD
  9. #7
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    And then there's the lag.
  10. #8
    Jul 2011
    Poole, Dorset
    6,548
    No lag at all mate.
    310.2bhp / 333ft/lb
    SOLD
  11. #9
    ...here we go again...
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Now you just need to clean that disgusting air filter!
  12. #10
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Was put through the dishwasher after I finished.
  13. #11
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    What tablets did you use on them ?.
  14. #12
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    I didn't, wasn't sure whether use detergent or not, I text MRP, but they went in before he replied, he said dishwasher detergent for future reference.
  15. #13
    Trader
    No Longer a trader.
    Tomcat's Avatar
    Aug 2004
    Sunning it up in Chorley
    2,980
    Dishwasher??... Really?.. Oh dear god,lol... You know you're supposed to clean them inside out (ie.. rinse them from the inside out) otherwise you're just pushing any trapped dirt deeper into the filter. Hope you're gonna re oil them afterwards...
    Previous cars:
  16. #14
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    What do the manufacturer say you should use to clean them ?.
  17. #15
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Quote Originally Posted by Tomcat View Post
    After an 1 1/2 hours in the dishwasher (its shortest cycle) I think all the dirt has been pushed through, and out. I've got some pipercross oil, but not sure if it's suitable for K&N filters, as the Pipercross are sponge, and the K&N cotton.
  18. #16
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    They don't mention dishwashers strangely enough
  19. #17
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Just had a look and found this !.
    http://www.knfilters.com/video/KN_Ai...r_cleaning.htm
    http://www.google.co.uk/url?sa=t&rct...g8-1vWuXx9Z_jw
  20. #18
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Yeah, I've seen them before, been using K&N filters for donkey's years, the dishwasher method is a lot easier.
  21. #19
    VPCUK Car of the Year 2013
    Jim
    Jamest5r's Avatar
    Feb 2009
    Kangaroo land
    7,069
    I'm a.fan of the dishwasher as well
  22. The Following User Says Thank You to Jamest5r For This Useful Post:
    stribo (Monday 2nd June 2014)
  23. #20
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Quote Originally Posted by Jamest5r View Post
    Rachel's gutted it's not big enough to fit a wheel in.
