Results 1 to 16 of 16
    Liddo's Avatar
    Oct 2005
    Skelmersdale, Lancs
    341
    Aircon not kicking in! Poss engine swap cause?
    My aircon isn't working. I'm not sure it was working before I had the engine replaced in my V70 either, but you can't hear it kicking in. I took it to Kwik Fit today for an MOT and re-gas. The guy said it's full to the brim with gas now, there's no leaks, but the compressor doesn't seem to be kicking in. I've checked the fuses, and the connection to the pump, and all is ok.
    What else do I need to check?? Could there be "other" connections loose anywhere??
    Cheers
    Thankyou, Goodnight....much love
    Gearbox Killer
    Proving the power of the
    15g....13.4@104.3mph
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    silly question I know, but is it plugged in and the earth ok, clutch on it is electrical if it's anything like the 850/v70 p1 ones
  3. The Following User Says Thank You to MoleT-5R For This Useful Post:
    Liddo (Friday 30th May 2014)
  4. #3
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Are the wires on the pressure switch still fitted ?.
  5. The Following User Says Thank You to Harvey For This Useful Post:
  6. #4
    Swollen Member
    stephenevans99's Avatar
    May 2006
    1,487
    Pressure switch connected? Funnily enough though, I can't recall seeing a low pressure switch on mine.
  7. The Following User Says Thank You to stephenevans99 For This Useful Post:
  8. #5
    Liddo's Avatar
    Oct 2005
    Skelmersdale, Lancs
    341
    Cheers chaps and errrrrrrrrrrrr, WTF is the switch
  9. #6
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Number 11 in photo looks like the pressure switch.
    http://www.volvopartswebstore.com/sh...ssembly=241852
  10. The Following User Says Thank You to Harvey For This Useful Post:
    Liddo (Saturday 31st May 2014)
  11. #7
    Swollen Member
    May 2006
    1,487
    That's why I've never seen it lol
  12. The Following User Says Thank You to stephenevans99 For This Useful Post:
  13. #8
    Liddo's Avatar
    Oct 2005
    Skelmersdale, Lancs
    341
    Cheers Harvey, do I get to it from below or on top?? Wonder why it'd need to be unplugged for an engine swap??
    Will take a look today
  14. #9
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    I would think you could se it only from above as it's right under the drivers side headlight unit ?.
  15. #10
    Liddo's Avatar
    Oct 2005
    Skelmersdale, Lancs
    341
    Ok mate, cheers, will check it in a bit
  16. #11
    Liddo's Avatar
    Oct 2005
    Skelmersdale, Lancs
    341
    Nope, can't see anything or any unplugged bits �� Will jack it up and look from underneath.
    Anyone got any photos of where I should be looking??
  17. #12
    Liddo's Avatar
    Oct 2005
    Skelmersdale, Lancs
    341
    Well, i still cant find anything that looks like a switch! This is a pic from behind my drivers headlight
    This is a pic of "something" I found near the washer filler! Should it be plugged into something??
  18. #13
    ...here we go again...
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    The switch in the schematic that Harvey posted sits on top of the dryer (of which there are two types). I believe it changed on the facelift models.
    It is indeed a low pressure switch and is a biatch to get to. I thinks it's possible to access with the Fan cowling removed otherwise you'll need to remove the front bumper.
    Location is tight up against the left hand side (as you face the car) of the 'Rad pack', below the O/S/F intercooler hose.
  19. The Following User Says Thank You to LeeT5 For This Useful Post:
    Liddo (Tuesday 3rd June 2014)
  20. #14
    Liddo's Avatar
    Oct 2005
    Skelmersdale, Lancs
    341
    Quote Originally Posted by Liddo View Post
    LOL! Cheers Steve......now, why the F would the be disconnected
  21. #15
    Liddo's Avatar
    Oct 2005
    Skelmersdale, Lancs
    341
    Quote Originally Posted by LeeT5 View Post
    Cheers Lee,
    So I doubt that would of been touched when the engine was swapped, as the rads werent moved. They unbolted the subframe and dropped it down!
    Hmmmmmm
  22. #16
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    it is a common failure for the compressor clutch to fail!
    If the clutch was buggered then you wouldn't know it, because it will just free wheel.
    Heres a good video explaining how it works and why it fails:
    http://www.youtube.com/watch?v=2CBeTPVRN80
    I strongly advise you don't do the bodged repair thou.
  23. The Following User Says Thank You to LeeT5 For This Useful Post:
