The top bush on my car is split, this one >
Is it hard to replace, any special tools needed?
A couple of spanners should do, a socket set if you can stretch to it.
LiamT4 (Tuesday 27th May 2014)
Parts For Volvos did the How To on that bushing although it was the square one the basics are the same, I did one for the small bushing behind it and the Lower Torque Rod. Here's the link to the PFV one...
http://www.vpcuk.org/forums/showthre...nting-pictures
So, spanners, socket set and screwdriver and hammer to get the bush out? Think i've got all those
JamesT5 (Tuesday 27th May 2014)
15 and 18mm spanner and a 18mm socket if changing the full mount.
Just going for standard bush, don't want anything that will transfer any vibrations and won't have the car for long so normal should be fine.
Its a facelift car so.will probobly be a sq one anyway
I'll have a look when it stops raining, check whats on it.
Could well be a round one mate, Sharkey Rs facelift car has a round one, whereas our pre facelift has a square one, I think it's a case of fitting whatever was to hand at the time.
Mine is 2001 and it has a square one. I think it was literally whatever the guy in the factory picked out of the parts bucket on the line.
Been busy the last few days, looking at stuff for the new house, after finally getting round to opening the bonnet mine is definitely a round one.
Looks like this one http://www.partsforvolvosonline.com/...oducts_id=6755
Looks straight forward enough. Undo the bolt on the old bush, loosen the bolt on the rear of the mount so it can swing out of the way. Remove old bush, replace with new, move bracket back in place and then fit and tighten all screws. Simple.
Yep... That simples
310.2bhp / 333ft/lb
SOLD
Got an old discovery now.
