Results 1 to 20 of 20
    May 2013
    22
    940 wideband kit
    getting the last few bits ordered before i start fitting a 16/19t with whites and supporting mods to my b230fk, but what wideband kit should i be looking for? there's so many differnt brands, i don't know nothing about this kinda thing so will be getting some help with this, don't know what afr it should be at? don't want to go out and waste my money on a rubbish kit.
    will be getting my turbo machined in the next few days and sending it off to be balanced, so hoping to get going with fitting it soon.
    and while im here are white injectors out of a 850 t5 high res? ie do they need the resistor mod? i know they need to be run at 4 bar but forget if there high res
    cheers
    smithy's Avatar
    Apr 2006
    1,752
    Are you ging to use a 3in maf if so I would fit minimum blues or greens .perfect size for 3in maf would be 460cc .i know that the vxr470 blues work well too .i ran me7 blues at over 4bar pressure to fuel my is turbo a t35 hydrid at 19psi .
    May 2013
    22
    yea i will be using a 3" maf, im on the lookout for a 012 and if i cannot find one i will put my maf guts in a 3" pipe, reason i was going to use whites is because i was given a set and a adjustable fpr when i bought my turbo, are saab greens any good? not sure what model there off but i know i can get a set of saab greens.
    i bet yours was interesting with a t35 at 19psi, what power was it running?
    cheers
    a 19t just isn't laggy enough
    p fandango's Avatar
    Aug 2004
    4,216
    i've got an Innovate wideband kit which quite a few people use, £140 & never seen any complaints
  5. The Following User Says Thank You to p fandango For This Useful Post:
    wiganer31 (Wednesday 21st May 2014)
  6. #5
    May 2013
    22
    Quote Originally Posted by p fandango View Post
    you got a link to the same one as yours mate? the innovate ones look pretty good
    cheers
  7. #6
    p fandango's Avatar
    Aug 2004
    4,216
    Quote Originally Posted by wiganer31 View Post
    sure this is the one i've got LINK, looks like its gone up £20
  8. The Following User Says Thank You to p fandango For This Useful Post:
    wiganer31 (Thursday 22nd May 2014)
  9. #7
    Blah Blah Blah!
    Volvostorm's Avatar
    Nov 2008
    Condover
    92
    I have the same Innovate kits, works well, once you connect the gauge to the wideband output, and not the narrowband! lol
  10. The Following User Says Thank You to Volvostorm For This Useful Post:
  11. #8
    May 2013
    22
    cheers
    cheers pal, they would go up when i want one lol, worth it for a kit that's try'ed and tested
  12. #9
    May 2013
    22
    Quote Originally Posted by Pault5estate View Post
    cheers, make abit of a mistake connecting it up then? lol
    cheers
  13. #10
    May 2013
    22
    out of interest, dose anyone know what cc that orange injectors are? a friend has just given me a set
  14. #11
    VPCUK Car of the Year 2013
    Jim
    Jamest5r's Avatar
    Feb 2009
    Kangaroo land
    7,069
    310 maybe....
    Or 325 can't remember fandango has a list I'm sure he'll post it
  15. #12
    May 2013
    22
    i was thinking around the same,i will keep hold of them while i have them
  16. #13
    p fandango's Avatar
    Aug 2004
    4,216
    315cc
  17. The Following User Says Thank You to p fandango For This Useful Post:
    Jamest5r (Friday 23rd May 2014)
  18. #14
    Jim
    Jamest5r's Avatar
    Feb 2009
    Kangaroo land
    7,069
    315cc
    Dam close lol
  19. #15
    May 2013
    22
    i know it might not be ideal to tell from a picture but can anyone confirm the exhaust side on the right in this picture if for a td04 16t?
    i need a new one for my turbo but just want to be sure its the correct one as its a fair travel to pick it up
    cheers
  20. #16
    p fandango's Avatar
    Aug 2004
    4,216
    all we can tell is its an angled 3" exhaust, the 16t part refers to the housing & compressor wheel which are on the other side of the turbo. The 16t came with both straight & angled exhaust housings
  21. #17
    May 2013
    22
    ahh ok thanks, all i know is the guy said its for a s70r/v70r, it is for the 16t thats going on my 940, so aslong as its ok for what i need then its all good?
    cheers
  22. #18
    May 2013
    22
    turns out the exhaust side pictured above was the one i was after and i now have to, the chra is going in to be machined on friday, so hopefully get the 19t kit fitted and checked over the weekend then i can send it off to be balanced and its almost there, just need to order a wideband kit, plugs and timing belt kit and i can start with the conversion, o and maf sensor
    cheers
  23. The Following User Says Thank You to wiganer31 For This Useful Post:
    artfulflounder (Wednesday 28th May 2014)
  24. #19
    May 2013
    22
    stripped my 16t down tonight, ready to be machined on friday, going to measure everything tomorrow and just check how much the chra needs machining by because ive forgot all the measurements i have had bits for that long, off the top of my head i think its 2mm? the bearings all seem in good condition but there all being replaced anyways
  25. #20
    May 2013
    22
    my turbo is now machined and temp built up to check it out, all seems well, going to get it balanced next and fit the rebuild kit and then its done
