I believe it was the wangle flange.
Flange
310.2bhp / 333ft/lb
SOLD
Got an old discovery now.
Sorry lads been out alday fone went dead! Went to my mate at volvo today plugged it in came up with air con sensor which iv ripped out so no problem and air temp he reset it and the lights stayed off but got another problem now after leaving the car for a couple of hours it takes a couple of seconds to start up like its ran out of fuel wen I had my other injectors on it fires up straight away?
It may possibly be chucking too much fuel in, or there could be an air leak so fuel's not getting to the injectors straight away.
could be a leaky injector
[QUOTE=merc85;712042]could be a leaky
how wud I know if one was leaking?
I used my old o rings do u reckon it cud be them and that I need some new ones
stribo (Thursday 15th May 2014)
The car will run fine with a leaky injector, Yes id replac the O rings as a matter of course, top and bottom o ring's, carful with the plastic pintle's as these can be fragile.
If it starts ok with the old injectors but not with the new ones then summit is up with the replacment ones.
That will be a injector/s leaking two possible causes they could have been damaged when being cleaned and no able to hold pressure or the seals are shot also try a smear of oil on the o rings before you fit them.
Also if your fed up of it cranking for a few seconds when going to start the car leave the ignition on red and let the pressure build back up for a few seconds then go to crank
merc85 (Thursday 15th May 2014)
If it helps mate, your car sounded the tits on way back Sunday, its very loud.
Hybusamini (Thursday 15th May 2014)
I have a set of whites here that are known to be working, wanna try em?
310.2bhp / 333ft/lb
SOLD
