Results 1 to 15 of 15
Thread: Oil change
    Yay....it's fixed
    Craigtange's Avatar
    Nov 2013
    Aberdeen, Scotland
    102
    Oil change
    Hi guys, any one know which is the best oil to use on my 2005 v70 r as there seems to be quite a lot of different answers and would you advise an engine flush. 135 k miles on the car
    Trader
    merc85's Avatar
    Sep 2010
    Harwich Essex
    4,987
    dont use a engine flush, comma list 5w40
    http://www.commaoil.com/products/results/91035275
  3. The Following User Says Thank You to merc85 For This Useful Post:
    Craigtange (Monday 12th May 2014)
  4. #3
    Trader
    Kingsford G's Avatar
    Nov 2011
    Colchester,Essex
    1,352
    0w30 is recommended but wouldn't use that tbh.I use 5w40.
  5. #4
    Jul 2011
    wallasey
    19
    I've started using petronas syntium 3000 5w40 get it from euro parts for 20quid for 4l its very good oil.
  6. The Following User Says Thank You to ROZER For This Useful Post:
  7. #5
    Kawasaki T5. Built by a Swede,
    Driven by a turnip!
    T5RatherAmusin's Avatar
    May 2013
    SW Wales
    303
    http://www.eurocarparts.com/ecp/p/ca...11&0&1&cc5_248
    promo code oil30 brings it at 20.99 for 5litres of shell
  8. The Following User Says Thank You to T5RatherAmusin For This Useful Post:
  9. #6
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    5w30 A5/B5 oil that's what mine gets. The A5/B5 is a better oil than A1/B1
    Is their a label on the underside of the bonnet as some have .
    The oil meets the spec. Most A5/B5 oils are 0w30 as it's a thinner oil fuel saving spec side of things.
    http://www.google.co.uk/url?sa=t&rct...0UxnvZ953D8osg
    Try the oil finder with this one it does list 3 different oils for my car dependent on the year of car.
    http://www.mobil.co.uk/UK-English-LC...which-oil.aspx
  10. The Following 2 Users Say Thank You to Harvey For This Useful Post:
    Craigtange (Monday 12th May 2014),ROZER (Sunday 11th May 2014)
  11. #7
    Feb 2012
    135
    Comma oil fully synth was in my V70 T5 when i bought it and once living in Kent near where they blended it, all my mates used Comma .....but now it is still not a good oil for quietness of the engine.....in fact i would never ever go near it for a T5!
    On the earlier motor with no VVT the 10W 40 grade oil is great for performance and smoothness but later engines with VVT the 30 grade is better as recommended by Volvo as if not used the VVT life may be limited and cause problems!
    Each to there own...
    Mercedes C320CDI Sport Estate 3 litre V6 7 Gear Auto
    Remap 290bhp 628Nm torque @ 1600revs 45.1mpg
  12. The Following User Says Thank You to 960kg For This Useful Post:
  13. #8
    Jul 2008
    154
    Quote Originally Posted by 960kg View Post
    I'v used Comma oil for years with diesel and petrol engines and never had an issue with it.
    Its as quiet as a mouse, no noise whatsoever in any engine including mower if you use the decent stuff.
    Craig if you or someone you know has an account with Dingbro they stock the full range of Comma oil.
    http://www.dingbro.com/
  14. The Following User Says Thank You to Jimmie For This Useful Post:
  15. #9
    Jul 2011
    wallasey
    19
    my oil stays in for 3k only and its out so as long as its above a1 and b1 then I don't care too much for really expensive oil.
  16. The Following User Says Thank You to ROZER For This Useful Post:
  17. #10
    Feb 2012
    135
    Quote Originally Posted by Jimmie View Post
    Fairy nuf ......my Father used to get in a rut and never knew how other oils had progressed until he tried them and never went back!
  18. The Following User Says Thank You to 960kg For This Useful Post:
  19. #11
    Yay....it's fixed
    Craigtange's Avatar
    Nov 2013
    Aberdeen, Scotland
    102
    Stupid question time.. Fully or semi synthetic, which one would give quietest smoothest engine running.
    Just asking this because after my last oil change I started getting noisy tappets, I put this form to the garage using inferior oil.
  20. #12
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    We use 0w30 fully synth in our S60R.
  21. #13
    Jul 2008
    154
    You're wrong on that one as i HAVE used other makes of oil.
    Did you not know that comma used to be owned by esso?
    I have also progressed from owning a Volvo 145/245 therefore i'm maybe not that old fashioned.lol
  22. #14
    Randomly Typed Username
    Iraq Lobster
    jamesy12345's Avatar
    May 2013
    lives on Standard Row
    4,606
    Quote Originally Posted by Craigtange View Post
    I think it would depend on the viscosity of the oil, fella, not about whether it is sythetic
  23. #15
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Engine Flush and then some Zero Twenty grade oil off of ebay.... no don't!
    People recommended 10W-40 to me, perhaps some Castrol Magnatec or something like that, I prefer using a genuine Volvo Oil filter as well.
