As Plodmonkey says above it's the Euro 3 engine, without the Diesel Particulate Filter. Euro 3 is an emissions standard. I was just trying to work out if it had an in-tank/low pressure pump, which I believe it does
So the electric pump in the tank should be priming the lines when you turn the ignition on....but if there is an air lock then the pressure might not be enough to force the diesel through.
If it was my car I would....
*check the diesel level (as you have)
*make sure the fuel filter was full (as you have)
*confirm the low pressure pump is working as it should, not hearing a noise doesn't mean it's knackered but would be good to confirm this
*crank it over a good few times, make sure the battery has good charge! The link below says 5 secs at a time but I doubt this would do it
http://www.justanswer.com/uk-car/3uv...el-system.html
Beyond that fella it sounds like you need someone to come and take a look
