Hi everybody. My name is Nick and I own a 2005 S80, 2.4 D5 for about 6 months now. I never had any problems with it until a few days ago when a red triangle appeared in the dashboard along with the message ENGINE SYSTEM SERVICE URGENT, and the car went into limp mode with no power and no revs whatsoever. I've stopped the engine and turned it on again and everything came to normal. This happened about 3 times this week. Yesterday morning when I was on my way to work, I was doing 40 mph and suddenly the message and the red triangle appeared again about 4 times in 3 miles. Eventually, the engine stopped exactly in front of my workplace (lucky me) and it didn't wanted to start again. A colleague of mine plugged in an ODB reader and it came with "P0094 Fuel System Leak Detected" fault. According to some volvo forums, the fault may be caused by the fuel filter being blocked. So I've changed straight away. Now, there is fuel in the filter, there is fuel in the feeding pipe but the engine still doesn't wants to start. How can I check if the high pressure pump or the injectors are working? What can be the problem? Anyone experienced something similar? Is it common fault on D5 engines? Thank you!
