I understand the 850r clutch is the one i need for my 850, where is the cheapest/best place to get one, what other bits should i do at the same time?
cheers
cheers
The only place you can get a 850R is from Volvo at around £200
Saches/UK clutches don`t make them anymore
mike 850 (Tuesday 6th May 2014)
Yes your options are RUFE /PFV you will need a release bearing too may as well get the crank shaft oil seal while your there......
1995 854 t5r
