Page 1 of 3 123 LastLast
Results 1 to 20 of 48
Thread: problem
    Feb 2006
    manchester
    628
    problem
    Hi not sure how to describe the problem when I set of car seem to get to 5 thosand revs but doesnt get any speed up if u doing 40 mph and floor it car goes to 4 or 5 thousand revs but doesnt move just holds revs at 5 thousand then u have to ease up on the pedal cars a v70 r auto thanks
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Quote Originally Posted by abdul View Post
    Eh?
    Jul 2008
    2,869
    Auto you say?
    Have you checked the fluid for condition and level? Any warning lights on?
    How old is the car? Is it a switchable mode box in an earlier car or is it an adaptive box?
    Gun Metal Grey - Volvo 850R - Saloon
    Thanks to Russ and team www.rtmechanics.co.uk
  4. The Following User Says Thank You to AndysR For This Useful Post:
    abdul (Sunday 27th April 2014)
  5. #4
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    Sounds like the box / torque converter is on the way out
    PIC][/SIGPIC]
    aaaaaaaaaaaaaaaaaaaaaaaaa
  6. The Following User Says Thank You to claymore For This Useful Post:
  7. #5
    SpongeBob Foamypants
    Back in a V70 and happy!!
    foammanmark's Avatar
    Nov 2011
    Nowhere near Blackburn.....
    1,604
    Laser or Saffy Abdul?
  8. #6
    Feb 2006
    manchester
    628
    Quote Originally Posted by AndysR View Post
    Auto you say?
    Fluid level seems to be fine colour looks good its a v70 r 1998 3 speed auto with 3 sports mode
  9. #7
    Feb 2006
    manchester
    628
    Quote Originally Posted by foammanmark View Post
    Saffy
  10. #8
    Feb 2006
    manchester
    628
    Cars fine at idle just when u are flooring it
  11. #9
    Feb 2006
    manchester
    628
    Could I have a pipe leaking
  12. #10
    Nov 2011
    1,604
    Saffy
    Still not good, but I was hoping it wasn't Laser, as she had a new box etc. not that long ago. Is this a sudden occurrence with saffy?
  13. #11
    Feb 2006
    manchester
    628
    Yes started a few days ago all of a sudden thought it might be a pipe come off or something
  14. #12
    Feb 2006
    manchester
    628
    Theres no flashing lights on the dash
  15. #13
    Jul 2008
    2,869
    Ok, is the gearbox playing up or is the engine just not producing the power to get it going like it used to? It is possible that a blown boost hose would cause the car not to accelerate properly but with a hose off the engine would stall of the maf is working correctly..
    Does it alter the way the box performs of you use the L or 3 positions on the lever?
  16. #14
    Feb 2006
    manchester
    628
    Not sure of the l or 3 position will check that in the morning if its fine in 3 position would that indicate box is ok
  17. #15
    Feb 2006
    manchester
    628
    Would having the codes read tell me what the problem is
  18. #16
    Jul 2008
    2,869
    "Could" indicate an electronic fault rather than a mechanical issue, if your driving it tomorrow drive off as you would in "D" up to 15/20mph. Then once you've reached this speed push the sport button and put the lever in "L" provided you don't use the kickdown at the bottom of the accelerator pedal and the road speed doesn't drop below 5 mph the gearbox should select 2nd, and stay in 2nd it won't upshift, once the car is in 2nd see how the engine performs with moderate to heavy throttle, where possible, to see if the box is slipping or the engine is not producing full power. If the box goes into second and the engine seems to be pulling normally but the revs just instantly shoot up then it sounds like the box is shot
    Never hurts
  19. The Following User Says Thank You to AndysR For This Useful Post:
  20. #17
    Feb 2006
    manchester
    628
    Going to give it a try tomorrow
  21. The Following User Says Thank You to abdul For This Useful Post:
    AndysR (Sunday 27th April 2014)
  22. #18
    Trader
    Kingsford G's Avatar
    Nov 2011
    Colchester,Essex
    1,352
    From the above description I understand the car revs up but doesn`t go so you need a new gearbox.As a cheaper option I`d fluch the fluid 1st and see how she behaves.
  23. The Following User Says Thank You to Kingsford G For This Useful Post:
  24. #19
    Feb 2006
    manchester
    628
    Quote Originally Posted by Kingsford G View Post
    Car goes and drives but when u try putting your foot down it revs to 5 tousand and doesnt do anything I have no lights flashing on the dash
  25. #20
    Feb 2006
    manchester
    628
    I can still drive the car been done abt 30 miles at 70 plus mph
