Page 1 of 11 123 ... LastLast
Results 1 to 20 of 215
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Exclamation Blue Smoke and Smell of Oil and Petrol
    Had a fab drive back from work tonight, even stopped at Aldi on the way home and as I pulled on to my drive and came to a stop, the engine was idling virtually at stalling point and then to my horror I saw blue-white smoke from the tail pipe and could smell burning oil and neat petrol. This came without warning although the car has had this choking idle issue before but recovered. It's also refused to start, once at MRP's place and several times prior to today - the car would try and start but hardly climb above stalling revs.
    Anyway, I've called the AA seeing as I have garage cover but why this without warning I'm not quite sure. I've got to get to work tomorrow so I hope it's an easy fix.
    So far I have checked the engine bay for oil leaks (non obvious), engine oil looks fine, no error codes (especially looking for mis-fire errors on the cylinders). I could do a cylinder compression test and take the spark plugs out but the AA are on their way so I'll let them do that seeing I pay for the privilege.
    Bit worried here I've got to be honest but I'll keep you all posted. Anyone else had this issue?
    p.s. I have got some video footage that I'll try and upload.
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Not sounding good,could be turbo have a look at the boost pipes for oil,is the water level ok ?.
    If there is a lot of oil getting into the cylinders that will stop the plugs working so the petrol can't get burnt. Just hope it's not to bad good luck.
  3. The Following User Says Thank You to Harvey For This Useful Post:
    JamesT5 (Saturday 26th April 2014)
  4. #3
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    My instinct is valve stem seal or knackered con rod.
  5. #4
    Another day,Another part. The
    Volvo pile is getting bigger
    Feb 2014
    Fleetwood lancs, uk
    72
    Maybe it's because you have all these black bushes in your car. At the end of the day bushes are there to take the vibrations away from the people/equipment/electronics and the torque away fixing points otherwise the mountings flex and in the end snap. But also equipment that as not been designed to take vibration. I think you will kill your car very soon (shaken car syndrome) very nut and bolt/mounting/fixing/weld/sheet metal/microchip/solder joint/glass that is after the bushes will start to fail and fail very fast as none of it was designed to survive under these conditions. Please don't take this the wrong way as I don't wish to provoke you in anyway, it's just how I see it.
  6. #5
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Quote Originally Posted by soothingduck View Post
    The black bushes aren't that hard, honestly! I seriously doubt some Polyurethane suspension bushes would cause this.
  7. #6
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    Quote Originally Posted by JamesT5 View Post
    Stem seals usually only smoke first thing in the morning as oil had drained into the cylinders over night,
    PIC][/SIGPIC]
    aaaaaaaaaaaaaaaaaaaaaaaaa
  8. The Following User Says Thank You to claymore For This Useful Post:
  9. #7
    Feb 2014
    Fleetwood lancs, uk
    72
    Yeah its not seals and I doubt its con-rod because it would be knocking like billy oh
  10. #8
    trying hard to look busy!
    jdavis's Avatar
    Dec 2008
    Doncaster, South Yorkshire
    1,050
    Turbo failure
    It's a 5 Cylinder Orchestra!
  11. The Following User Says Thank You to jdavis For This Useful Post:
  12. #9
    Feb 2014
    Fleetwood lancs, uk
    72
    Quote Originally Posted by jdavis View Post
    Turbo failure
    Yeah could be
  13. #10
    Beer Baron
    LiamT4's Avatar
    Jan 2010
    Leicester
    1,849
    Have you checked the oil and the water?
  14. #11
    Driving old Volvos, because im
    cool!
    timbo's Avatar
    Mar 2012
    Doncaster/Lincoln
    205
    Compression test and a sniff test of the coolant?? Has performance been down recently? ?headgasket?
  15. #12
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    I would be suspecting turbo
    PIC][/SIGPIC]
  16. The Following User Says Thank You to claymore For This Useful Post:
  17. #13
    Beer Baron
    LiamT4's Avatar
    Jan 2010
    Leicester
    1,849
    If its the turbo, how does that affect the idle?
  18. #14
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    It could be sucking in oil
    PIC][/SIGPIC]
  19. The Following User Says Thank You to claymore For This Useful Post:
    LiamT4 (Saturday 26th April 2014)
  20. #15
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,548
    Dead coil pack... Or two?
    310.2bhp / 333ft/lb
    SOLD
    Got an old discovery now.
  21. #16
    Norfolk born and bred.
    Give me a high 6!!!
    silverhorse's Avatar
    Oct 2012
    Great Moulton Norfolk NR15
    221
    Hate to say it mate, but does not sound too good. Could be a few things, but they all have the ability to seriously lighten your wallet. Car engines are not designed to burn oil, so when they do there is something amiss.
    Bloody hell James, I hope this is something simple. (and cheap!!!)
    Me: 2005 V70 2.4 T5 SE. All standard.
    The Wife: 2008 C70 2.5 T5 SE. All standard.
  22. The Following User Says Thank You to silverhorse For This Useful Post:
  23. #17
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Update!
    The AA have been out and I went through the possible causes with the patrol man. We removed the coil packs and spark plugs and they were all fine, no oil and no signs of any issues there. Tried adding some petrol just to rule out that as a very remote possibility and the car just seemed to 'choke' as it tried turning over, again a strong smell of petrol. The patrol man seemed to think that the smell of oil wasn't oil at all because there was no sign of it on the spark plugs or anywhere, he seemed to think what I smelled was actually petrol fumes and that what I have is a failure of the Turbo (as suspected by some of you above as well!) He also said the oil looks nice and clean and there was no issues with water levels either or any oil in the water for example.
    The AA are sending out another patrol in the morning for a "second opinion" but it's looking increasingly likely I'll be shopping for a second hand turbo very shortly.
    To turn a good in to a bad, is it worth me trying to get a bigger turbo here and killing two birds with one stone (i.e. more power potential)? I know there's different numbers like 16, 18 19 but I'm not sure I understand the system there and what's compatible and what will fit straight on. I'll be on a tight budget!
    I'll organise the videos of the car earlier just after the problem started, I'll post them up as soon as I can. Got to phone work now and tell them I won't in, in the morning. Another days wages lost!
  24. #18
    Trader
    Nov 2010
    chester le street
    969
    I hate to say it but poor oil choiced in the past will of done both engine and turbo no good what so ever. If its the turbo it will be easy to spot. Compression test would be the 2nd thing id do. 1st being checking turbo for play and oil.on the exhaust side
  25. #19
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    https://www.youtube.com/watch?v=WJdq...ature=youtu.be
    Make up your own minds about this....
  26. #20
    Blah Blah Blah!
    Volvostorm's Avatar
    Nov 2008
    Condover
    92
    When you turn the ingition on, can you hear the fuel pump?
    Mine sounds like that when the fuel pump died, or I've forgotten to turn it on!
  27. The Following User Says Thank You to Volvostorm For This Useful Post:
