Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Exclamation Fuel Flap Won't Unlock
    I went to fill up with V-Power tonight and the fuel flap was stuck locked. I tried everything from unlocking the car, pulling the battery, pulling the fuse and nothing released it so in the end I gave up and just drove home. I tried releasing it when I got home and nothing happened despite dead locking the car and then unlocking it again.
    Has this happened to anyone else? I suspect a solenoid has failed, pity it didn't fail the other way. But how the hell do I now refill my car because I need a manual release which probably means taking all the interior trim off the O/S of the car boot area. Failing that I'll have to try and lever the flap open with something.
    What a total PITA!
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    This happened to our R, I had to rip the fuel flap off to get petrol in it.
    Randomly Typed Username
    Iraq Lobster
    jamesy12345's Avatar
    May 2013
    lives on Standard Row
    4,606
    Have you got one of these in the boot??
  4. The Following User Says Thank You to jamesy12345 For This Useful Post:
    JamesT5 (Sunday 13th April 2014)
  5. #4
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    There is a way of manually releasing it from inside the car but it means a whole load of work. Ripping my fuel flap off is really not something I want to do tbh.
  6. #5
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Quote Originally Posted by jamesy12345 View Post
    Thanks mate, that's really useful. The carpet section is different on the V70 but once I've got to the motor the job should be simple enough.
  7. #6
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    I've just checked on the s60, and it was a 30 second job
    PIC][/SIGPIC]
    aaaaaaaaaaaaaaaaaaaaaaaaa
  8. The Following User Says Thank You to claymore For This Useful Post:
  9. #7
    Iraq Lobster
    May 2013
    4,606
    Quote Originally Posted by JamesT5 View Post
    ^^^That's what the video I posted is about
  10. #8
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Quote Originally Posted by claymore View Post
    Ok thanks Colin. I took the carpet cover off and couldn't see anything but I'll take a look in the morning or later on if there is enough daylight.
  11. #9
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Yeah, you replied as I was typing that message....
  12. #10
    Iraq Lobster
    May 2013
    4,606
    OK, just making it clear for future readers
    Hope it sorts you out
  13. The Following User Says Thank You to jamesy12345 For This Useful Post:
  14. #11
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Yes, I tried that but the bolt was seized, hence ripping the flap off.
  15. #12
    Iraq Lobster
    May 2013
    4,606
    Ouch.....looks like not much room in there for freeing off seized bolts
  16. #13
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Well, it's not a bolt as such, it's the plastic bit that slides across to lock the flap, there is a tab on it so you can slide it across, but because it was seized the tab snapped off.
  17. #14
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Found another useful link. Looks like the back cover has to come off as I suspected, obviously different from the S60 set up......
    http://www.justanswer.com/volvo/4k33...r-fuse-ok.html
  18. #15
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    I would be very surprised if it was that difficult, perhaps to replace the solenoid, but to open the flap should be easy, I'm pretty sure manufacturers have to provide a manual release mechanism.
    PIC][/SIGPIC]
  19. The Following User Says Thank You to claymore For This Useful Post:
  20. #16
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    You'd think wouldn't you Col, however although there is a tab to retract the locking pin:
    As ours was seized, when I pulled on the tab, it just snapped off, then you have no other alternative than to rip the door off, which is likely to break the hinge as well. The solenoid can only be removed once the door is open/removed.
  21. #17
    trying hard to look busy!
    jdavis's Avatar
    Dec 2008
    Doncaster, South Yorkshire
    1,050
    Mine did this when I first got it, just banged it while I unlocked car and it freed off. Bit of wd40 on the pin when I got home and all fine. Problem was waiting the 10 minutes with flap open waiting for it to lock to lube the pin.
    It's a 5 Cylinder Orchestra!
  22. The Following User Says Thank You to jdavis For This Useful Post:
    JamesT5 (Monday 14th April 2014)
  23. #18
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Well I've sorted it. I took all the interior trim and sound proofing off this morning and the plastic slider moved freely. It's now working again but for how long I don't know, I suspect I'll need as new unit at some point but for now I've got it working again having rest the thing manually.
    A photo of the location for any P2 V70 owners with the same issue....
    Thanks to all who gave advice above!
  24. #19
    Trader
    Ready for the weekend
    partsforvolvos.com's Avatar
    Jun 2012
    Rainy Wellingborough
    270
    iirc, saloon models have the wire loop to pull for emergency situations but estates don't ........ go figure!
    james, the motor is all the same - s60 s80 v70 xc90 so second hand is a strong possibility since a new one is £90 or so!
  25. The Following User Says Thank You to partsforvolvos.com For This Useful Post:
  26. #20
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Quote Originally Posted by partsforvolvos.com View Post
    S60s don't have a wire loop, don't know about the S80.
