Results 1 to 18 of 18
Thread: shimming block
    Trader
    Nov 2010
    chester le street
    969
    shimming block
    has anyone on here shimmed a block befor. just after a little bit of info as im in two minds weather to swap the heads myself or pay tim willams. the head swap is easy but while the head is off i might as well shim it. after some pointers from those who have done it befor
    Ghost Rider
    If I want your opinion, I'll
    ask you to fill out the
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
  3. The Following User Says Thank You to oblark For This Useful Post:
    graemewelch (Thursday 10th April 2014)
  4. #3
    Trader
    Nov 2010
    chester le street
    969
    can you remember of the top of your head what thickness it was, im guessing mine will different anyway. do the shims go all the way down the liners or just part of the way
  5. #4
    Trader
    Nov 2010
    chester le street
    969
    Quote Originally Posted by graemewelch View Post
    helps if i look on laptop and not the phone. roughly a inch.
  6. #5
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    Off the top of my head I think the gap was only 0.7mm and slot is about 10mm deep.
  7. #6
    smithy's Avatar
    Apr 2006
    1,752
    I didn't think the 2.4 block needed shimming at all .the 2.5 block flexs at the top of the bore that's why they shim them .even though I never had a problem with mine
  8. #7
    Trader
    Nov 2010
    chester le street
    969
    Quote Originally Posted by smithy View Post
    the head is comming off thats why im shimming it. would be daft not to. im going to runing a bit more power than standard to want it to be bullet proof or as bullet proof as it can be with out going for a fully forged engine with darton liners
  9. #8
    Gearbox Killer
    Proving the power of the
    15g....13.4@104.3mph
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    The 2.4's seem to need it when running high boost levels, Colin had to shim his block, it looks a simple job from what I have seen of Colin's and Rob's threads, I'd do it if I had the head off just for the peace of mind ( but then mines a 2.3 so no worries there...lol)
  10. #9
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,548
    Quote Originally Posted by MoleT5-R View Post
    The 2.3 isn't completely immune to split liners - it's not common but it has happened a few times from what I've read.
    310.2bhp / 333ft/lb
    SOLD
    Got an old discovery now.
  11. #10
    smithy's Avatar
    Apr 2006
    1,752
    I'm glad the redblock don't have these problems
  12. #11
    Gizza job!
    Yosser's Avatar
    Jul 2008
    The 1980's
    161
  13. #12
    Gearbox Killer
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    nice to know it's practically bulletproof ... but you need to get it on the track to test that fact....lol
  14. #13
    Trader
    Nov 2010
    chester le street
    969
    Quote Originally Posted by Yosser View Post
    quiet a lot of debate in that thread. think ill decied what will be best once ive removed the head.
  15. #14
    Gearbox Killer
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    Thinking about it and if I remember rightly, Colin shimmed his liners after they split so to stop the liner opening back up under load and heating, must have worked as that engine is pushing 428hp with no problems, sure he'll be along soon to add to this.
  16. #15
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    Yep, I split a liner, and after shimming it, it's been fine, the size of the shim will be different on each engine, a common trick is to buy 5 sets of feeler gauges and use the correct size for each cylinder.
    PIC][/SIGPIC]
    aaaaaaaaaaaaaaaaaaaaaaaaa
  17. The Following 2 Users Say Thank You to claymore For This Useful Post:
    Dangerous Dave (Thursday 10th April 2014),MoleT-5R (Thursday 10th April 2014)
  18. #16
    5 pot heart of a Volvo
    T5frankie's Avatar
    Apr 2006
    On the strip
    4,423
    being stuck in a garage all its life its gonna be bulletproof lol
  19. The Following 3 Users Say Thank You to T5frankie For This Useful Post:
    claymore (Thursday 10th April 2014),MoleT-5R (Thursday 10th April 2014),smithy (Thursday 10th April 2014)
  20. #17
    Gearbox Killer
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    Quote Originally Posted by claymore View Post
    that's a great idea for a five pot insurance policy
  21. #18
    Jul 2008
    6
    The gap would have been the same size on all of them when new I think. They are all be cut the same way. They appear to have been cut with a circular disc. Maybe if that was allowed to wear you may get a slight difference in size.
    Most variations are from the liners bending. High cylinder pressures will bend 81.5 mm bores.
  22. The Following User Says Thank You to shemtek_racing For This Useful Post:
    claymore (Tuesday 15th April 2014)
