drivers side wheel is red hot. im guessing its the caliper sticking but will inverstagate tomora sometime. anyone else had a sticky rear caliper
check the pins, pads and piston...
Just done donnas v40 thought that was stuck pot or slider but turned out to be hand brake unit thats external had seized
stribo (Thursday 20th March 2014)
20 quid for a seal kit. Arnt the pistons a complete pain to get back in once removed. Drivelink do new calipers for peanuts
Pistons can be a little fiddly to put back in with new seals but use some brake fluid on the rubbers and the slide a little better
Anyone used these ?.
http://www.brakepartssuperstore.org....-uk/d3730.html
Graeme go into your local motor factor and get the exchange price for the calipers.
You should set up an account with them if possible.
Interesting, Cheap and Quality do not normally go together, so I'll be watching this closely
To answer your original question, yes, mine has a sticking drivers side caliper although not as bad as yours by the sound of it
Going in to the menders next week before it gets any worse
2005 S60 T5 SE X PLOD RICA 300 MAP
I've had a sticking front caliper if you recall, some time ago. If your brake rota is an orange colour on the edge even when cold then it can indicate the disc has overheated. The disc is likely warped as well because that happened to my front one.
Might be worth taking the caliper off and cleaning the rust off the pitons and the tunnels they run through but in the end, I just replaced all of my calipers for new ones because where one is going the others probably aren't far behind.
