Hi peeps, as you know ive recently purchased a 1996 850r Auto, it has full history and the Auto box has had a fluid change at around 150k, she's now on 170 and i want to chnage the fluid as a precaution since my last 850 auto lol.
How do you guys do it? last time i did one we disconected the Return line ran the engine for a few seconds until it pumped out x amount, then refilled with the same amount, and repeated this until the fluid was Red.
Now ive read several people have actually drain the box from the bottom via the drain plug, Apparently this expels roughly 3.5 lts. then refit the plug the you refill with 2 litres of atf then run again thought the gears waiting 5 seconds in each gear before shifting to the next.
Finally once again when the fluid turns RED you top up usually 3 l- 3.5 litres and check the level in the normal matter.
Which way is best do you think??
