Right then folks
Have changed everything even abs ecu with all matching numbers to now find it needs to be coded to my flipping car
Can this be done without killing it who can do this bar a main stealer
Help please
Right then folks
Help please
C70 2.4 T Saffy Pearl now dead and stripped
850 T5 "the Turk" wagon
V70 D5 parked up for sale
V50 1.8s family wagon
Ello big fella
I believe Hamish has the means to flash these things. Worth giving him a call.
310.2bhp / 333ft/lb
SOLD
Got an old discovery now.
c70geoff (Monday 17th March 2014)
I changed my ABS ECU and it didn't need to be flashed??
I used these guys below....
https://www.midwest-abs.com/
(yeah I know in the US but there you go)
In the time I have been repairing ABS ECUs over the last 7 years - I have not heard of the requirement to code the ABS ECU to your car, not for the C70 Coupe for your model year at least. The repair either works or it doesn't (resoldering the pins). Usually the fault will clear itself or you can clear via ODB2.
Volvo ABS ECU Repair
c70geoff (Monday 17th March 2014),jamesy12345 (Monday 17th March 2014)
Have tried clearing using my snapon kit and comes back on after a few minutes
Changed rings, sensors the lot
Seriously loosing it with car now
What codes is it sending. If it is more than 1 corner then it is more likely a fault with the ECU & I would look to swap again just to be sure.
No communication with sensor if I remember rightly
You may end up having to send me your details Dave and I'll send my ecus to you please
have you read this?:
http://www.vpcuk.org/forums/showthre...intermittently
Harveys link is useful
http://www.ipdusa.com/techtips/10035/abs-tracs-codes
Third ecu here so will try that first and have ordered full set of sensors too
Abs issue sorted
Left front sensor fecked even though was new in sept just gone so Volvo own part in place and all good for now
Wobbly Dave (Wednesday 26th March 2014)
sadly it is the nature of the beast that it will be the last thing you try will be the fix. Good that you have it fixed finally.
True that Dave
Only reason I didn't check said item was that they where changed recent
But that's what u get buying cheap copy parts
And thanks as I'm glad to have her back too
