Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 76
  1. #41
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Will the fuel pump will only run if the rail pressure is low ?.try letting some pressure out at the test port.
  2. #42
    ...here we go again...
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Quote Originally Posted by MIKESC70T5 View Post
    Might be pissing up the wrong tree, but on my old T5R when I fitted samco coolant hoses the car wouldn't turn over afterwards. Worked out when changing the top hose, I dislodged the relay under the slam panel and it broke the wires. Fixed the wires back together, they are very fragile and the car started straight away. You mention changing the rad so possible you moved the hoses and caused the problem I had.
    I don't think your pissing up the wrong tree at all. He's changed the rad and intercooler so the relays that attach under the slam panel will all have been moved. If my memory serves me correct, the Starter motor relay is under there and the Main relay. If the main relay has a bad/broken connection then the fuel pump won't prime!!
  3. #43
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    New batteries? as in the key fob, that works fine, I have RAC cover, but not sure they'll be able to cure the problem.
    AA and RAC have full access to wiring diagrams and will easily be able to fix this fault, providing you come clean with what it is you've done. Many ppl lie or don't tell the whole truth and leave us second guessing or looking in the wrong place when they call us out, which doesn't do them any favours and can lead to your car being recovered to a garage. Being honest goes along way in getting the problem fixed. You can kick yourself afterwards if you want, at least your car will be working!
  4. The Following User Says Thank You to LeeT5 For This Useful Post:
    stribo (Sunday 16th March 2014)
  5. #44
    MIKESC70T5's Avatar
    Aug 2006
    Sunny Bournemouth
    851
    Quote Originally Posted by LeeT5 View Post
    I disagree, as I called the AA out when my old t5r wouldn't start, they tried new d/cap and rotor arm first then gave up lol. While they were arranging to get the car picked up to take to a garage, I came on this very forum and a member who hasn't been on here for years suggested checking the relays. The AA man was rather embarrassed lol. Maybe things have changed in recent years.
  6. #45
    MIKESC70T5's Avatar
    Aug 2006
    Sunny Bournemouth
    851
    If my suggestion fixes his problem, then Stribo, I'm expecting a free square burger at the next Vine meet lol.
  7. #46
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    If your suggestion fixes the problem Mike, I'll happily buy you a square burger.
  8. #47
    Southern AA patrol.
    AAnickmac's Avatar
    Aug 2013
    West sussex
    65
    Totally agree with this. Being honest at a breakdown is the best thing. I have been out to breakdowns where they tell you a load of lies because they are embarrassed to own up to what they have done. I just want to fix the car, not bothered what they done wrong, but need to know what they have touched.
  9. The Following User Says Thank You to AAnickmac For This Useful Post:
  10. #48
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    If I do have to call them out, I'll be totally honest with what I've done, just want the thing running.
  11. #49
    T5 powered and retro
    munster732's Avatar
    Apr 2012
    Barnsley,South Yorkshire
    171
    Square burger....square....burger? Glad I don't go down south very often, that's just wrong in so many ways!
  12. #50
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Quote Originally Posted by munster732 View Post
    Nothing wrong with a square burger mate, it's probably bigger than you.
  13. #51
    munster732's Avatar
    Apr 2012
    171
    I would give some sort of witty retort, but I've got to get ready for a lovely drive out in my gay golden performance volvo. How about you ;-)
  14. #52
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    I've got to go and hit mine with a hammer. Whilst you're out having your lovely drive, think of this:
  15. #53
    munster732's Avatar
    Apr 2012
    171
    Wow, that looks like a healthy sized burger, looking in relation if that's a pint pot behind it. I may even go over to the dark side one day and try a softies meet...if I can get Pete a passport to leave Barnsley !
  16. #54
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    You'd love it down here mate, shandy's easy to get.
  17. The Following User Says Thank You to stribo For This Useful Post:
    siamblue (Sunday 16th March 2014)
  18. #55
    MIKESC70T5's Avatar
    Aug 2006
    Sunny Bournemouth
    851
    You've been up since 5, so get off the forum and go and sort your relays out lol.
  19. #56
    Driving Miss Daisy
    V70 Graham's Avatar
    Feb 2012
    West London
    2,909
    Hahaha that's what I was thinking too Mike, sun's out as well.
  20. #57
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    I was watching the Grand Prix. All sorted, I hadn't pushed one of the main loom connectors properly Will update with pictures later.
  21. The Following User Says Thank You to stribo For This Useful Post:
  22. #58
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Good news then.
  23. The Following User Says Thank You to Harvey For This Useful Post:
  24. #59
    Southern AA patrol.
    AAnickmac's Avatar
    Aug 2013
    West sussex
    65
    Ha ha, glad it's sorted mate.
  25. The Following User Says Thank You to AAnickmac For This Useful Post:
  26. #60
    siamblue's Avatar
    Nov 2004
    Ilford,Essex.
    747
    At least it was a simple fix..
  27. The Following User Says Thank You to siamblue For This Useful Post:
