Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 76
  1. #21
    Lawnmower Boy
    Now known as WAPAHO!!!
    JUDGENINJA's Avatar
    Nov 2004
    Guildford, Surrey
    1,058
    Have you tried new batteries?
    RAC or AA?
    Current Garage:
    *Data Sept 2013
  2. #22
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Quote Originally Posted by JUDGENINJA View Post
    RAC or AA?
    New batteries? as in the key fob, that works fine, I have RAC cover, but not sure they'll be able to cure the problem.
  3. #23
    VPCUK Car of the Year 2013
    Jim
    Jamest5r's Avatar
    Feb 2009
    Kangaroo land
    7,069
    So what have you actually changed to make you think it's the immobiliser
  4. #24
    Southern AA patrol.
    AAnickmac's Avatar
    Aug 2013
    West sussex
    65
    if you have a multi meter, stick it on volts and go from neg post of battery with one lead and engine with the other lead. get some one to try start it and see what readings you get on the meter. it should be as near as zero as poss. if you get a reading then you have a bad earth. try it on the positive side next. pos post of battery to starter main post and see what you get there. again it should be as near to zero as possible. across both circuits you should not see more than 0.5 volts.
    if you get a reading on either of these circuits (volt drop/loss) you need to work your way through checking all the conections and/or earth straps/points.
    hope this helps, also what relay is it that is clicking? starter relay?
  5. The Following User Says Thank You to AAnickmac For This Useful Post:
    stribo (Saturday 15th March 2014)
  6. #25
    Feb 2012
    135
    You won`t get a click click click if it`s the immob. as it will not connect.
    It must be the Fuel Pump Relay then if not hearing the pump prime!!
    If you haven`t a spare take it out and clean the contact spades.
    Mercedes C320CDI Sport Estate 3 litre V6 7 Gear Auto
    Remap 290bhp 628Nm torque @ 1600revs 45.1mpg
  7. #26
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Quote Originally Posted by 960kg View Post
    Surely the starter would still operate even if the fuel pump relay had stopped working.
  8. #27
    Cookie Monster
    its getting there
    theflyingbrick's Avatar
    Jun 2011
    east london
    1,820
    yes it would..................but it sounds like the solenoid on the starter has packed up and im not sure how to fix it,i normally put a new starter on if that's the case,which again wont help you for commuting this week
    full respray..plenty of body mods..comets..ray cat back noise pipe..decat and wrapped downpipe..me7 exhaust manifold..3" throttle body with ported inlet manifold..blue injectors..adjustable fuel reg..reverse intercooler pipework..19t..open cone air filter..255 fuel pump..m-r-p short shift..boost gauge..unknown remap..adjustable suspension..lightweight crank pulley..n/a cams..stripped out interior..and a heavy right foot
  9. #28
    Driving Miss Daisy
    V70 Graham's Avatar
    Feb 2012
    West London
    2,909
    I had exactly the same problem 18 Months ago ME7 though.
  10. #29
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Quote Originally Posted by Jamest5r View Post
    I've changed the radiator and intercooler, the reason I think it's the immobiliser is because the fuel pump's not priming, and the starter's not operating, even though the battery has a full charge.
    Quote Originally Posted by theflyingbrick View Post
    But the starter solenoid wouldn't affect the fuel pump, and I find it hard to believe they've both packed up at the same time, although I'm not ruling it out entirely.
  11. #30
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Quote Originally Posted by V70 Graham View Post
    Hopefully it's not the ECU, still think it's the immobiliser, and reading on V.O.C. sounds like it could be the transponder aerial around the ignition switch.
  12. The Following User Says Thank You to stribo For This Useful Post:
    Biff (Saturday 15th March 2014)
  13. #31
    Jim
    Jamest5r's Avatar
    Feb 2009
    Kangaroo land
    7,069
    Get a piece of wire, put one end in the spade on the starter then touch the + on the battery see if it turns over
  14. The Following User Says Thank You to Jamest5r For This Useful Post:
  15. #32
    Driving Miss Daisy
    V70 Graham's Avatar
    Feb 2012
    West London
    2,909
    Can you not try the transponder from the cabbie ?
  16. #33
    Trader
    Nov 2010
    chester le street
    969
    bust it and sort the cabbie
    sorry mate only joking hope you get it sorted
  17. #34
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    I don't know if they're interchangeable, as the cabbie is ME7.
  18. #35
    Driving Miss Daisy
    V70 Graham's Avatar
    Feb 2012
    West London
    2,909
    I think Simon (deathrider) knows a fair bit about transponders iirc, I'm sure he gave me a few pointers.
  19. #36
    MIKESC70T5's Avatar
    Aug 2006
    Sunny Bournemouth
    851
    [QUOTE=stribo;695203]I've changed the radiator and intercooler, the reason I think it's the immobiliser is because the fuel pump's not priming, and the starter's not operating, even though the battery has a full charge.
    Might be pissing up the wrong tree, but on my old T5R when I fitted samco coolant hoses the car wouldn't turn over afterwards. Worked out when changing the top hose, I dislodged the relay under the slam panel and it broke the wires. Fixed the wires back together, they are very fragile and the car started straight away. You mention changing the rad so possible you moved the hoses and caused the problem I had.
  20. The Following User Says Thank You to MIKESC70T5 For This Useful Post:
  21. #37
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    [QUOTE=MIKESC70T5;695226]
    I'll check them tomorrow Mike, thanks.
  22. #38
    siamblue's Avatar
    Nov 2004
    Ilford,Essex.
    747
    I have a spare starter and transponder ring here you can have,but i can only get it too Guildford is that any good for you?
    as has been said,the relay on the slam panel,the wires can corrode on them.
  23. #39
    New Identity
    Dangerous Dave's Avatar
    Dec 2006
    West Midlands
    2,491
    Think that the engine should still turn over as the immobiliser doesn't control the starter circuit.
  24. #40
    Driving Miss Daisy
    V70 Graham's Avatar
    Feb 2012
    West London
    2,909
    Quote Originally Posted by Dangerous Dave View Post
    You are of course right Dave, I read the first post wrongly, thinking it was turning over but not starting.
    Hopefully something simple Steve, hope you get it sorted tomorrow.
