Results 1 to 15 of 15
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Thumbs up Fitting Upper Engine Mount Small Bush (V70/S60 P2)
    Fitting the Upper Engine Mount Small Bush was a little more complicated (though not difficult) than anticipated so I thought I would do a "How To" thread on the subject.
    Tools and Parts
    • 15, 17, 18, 19mm spanners and sockets
    • Electric Drill and Drill pieces
    • Hacksaw
    • Large Hammer/Mallet
    • Flat Headed Screwdriver
    • Grips/Pliers
    • Copper Grease
    • Powerflex Bushes
    Firstly, I used the spanners to remove the engine mount bar entirely.
    I then removed the bolt holding the two brackets to the rear bush, allowing access to remove it.
    Next, I drilled out the bush as the original is pressed in and is surrounded by a metal sleeve (like the wishbone bushes). Once it's drilled out enough I was able twist the centre rod out with a pair of plumbers grips.
    Next, it was time to remove the metal sleeve, I did this my using a hacksaw to cut to an incision in two places within the sleeve to weaken it, and then gave the sleeve a smack on the edge with the flat headed screwdriver and my hammer until the sleeve dropped out (I used a 4LB Sledgehammer). Out came the sleeve.......
    Once the sleeve was out, I was ready to fit the new Powerflex Bushing, this comes in two parts with a new metal centre rod. First I gave the bush and the hole in the engine mount bar a good coat of copper grease.
    Fitted the bush to the bar, this was a reassuringly tight fit but went in by hand without the need for any tools. It doesn't have to by perfect at this stage as when it's clamped back on the the car the action of bolting back together will finish pressing the bushing firmly in to place.
    Next, I reattached everything to the car, torqued the bolts up and now, along with the previously fitted top engine mount and strut brace tension bushes, I have a completely Powerflexed (Black Series) top engine mount assembly.
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Finished assembly.....
  3. The Following User Says Thank You to JamesT5 For This Useful Post:
    billnbenT5 (Sunday 15th March 2015)
  4. #3
    Driving Miss Daisy
    V70 Graham's Avatar
    Feb 2012
    West London
    2,909
    Nice write up James, well done.
  5. The Following User Says Thank You to V70 Graham For This Useful Post:
    JamesT5 (Thursday 13th March 2014)
  6. #4
    Feb 2006
    manchester
    628
    Good work
  7. The Following User Says Thank You to abdul For This Useful Post:
  8. #5
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Good work mate, have you noticed much difference with it fitted?
  9. The Following User Says Thank You to stribo For This Useful Post:
  10. #6
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    No, none at all however I 'know' it's done and I won't have to worry about those bushings again. With the Black Series, I'm finding once you fit the main player, the little bushes make no difference to the 'feel' but I know that they're all the same grade and in a kind of OCD way, I like to have them all the same.
    Mr Peachey is giving me some priceless assistance on Saturday fitting the newly Powerflexed front Control arms to the car and having had a chat to Martin tonight on the phone, we're also going to fit the new Meyle HD Droplinks and with a bit of luck, change the ABS pump motor over which will solve my ABS/Tracs problem.
    The MOT is due next week, if this car fails...........
  11. #7
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Quote Originally Posted by V70 Graham View Post
    My History teacher used to say that to me at School. Unfortunately no 'House Points' to be had here though....
  12. #8
    Trader
    merc85's Avatar
    Sep 2010
    Harwich Essex
    4,987
    What abs/tracs issue have you got? ive got a customer who has "Brake Pressure Sensor" fault code apearing from time to time, his is a 2005 v70 with dstc
  13. #9
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Quote Originally Posted by JamesT5 View Post
    Then you'll get the problem sorted, you've come too far to do otherwise now.
  14. The Following User Says Thank You to stribo For This Useful Post:
  15. #10
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Quote Originally Posted by merc85 View Post
    Vida diagnostics on 3 separate occasions have all thrown up the ABS pump fault code (Vida code is something like 0070). I tried Ed's (Leeds_Finest) suggestion to leave the pump and module in place but loosen off the fuse box, and take the two pin connector from the old pump out of the ABS Module and connect a replacement pump in. Then, started the ignition and the ABS lights went out confirming the Vida diagnostic, this worked for Ed and he had the same issue as me.
  16. The Following User Says Thank You to JamesT5 For This Useful Post:
    merc85 (Thursday 13th March 2014)
  17. #11
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    In terms of being 'solid' underneath, I've now almost totally eradicated the original owners total disregard for suspension and running gear issues although the back end bushings haven't yet been touched (it's next on my priority list and will be Powerflexing that as well). The emissions test is my biggest concern, especially given the 'tap, tap, tap, tap, tap, tap' on the cold starts coming from the passenger side of the engine bay.
    Brakes are in good condition and no major bodywork issues. I always check all the lights before the MOT to make sure I won't fail on the really stupid stuff like a blown bulb.
    With all the work I've had done on the car I expect it to come out that Ministry Of Transport Test smelling of Roses next week.
  18. #12
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    On a foot note, I'm just glad alloy wheel condition isn't part of the test, if it was I might as well pick up that VT30 now...
  19. #13
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,548
    good work there mate, bigger drill needed but solid job
    310.2bhp / 333ft/lb
    SOLD
    Got an old discovery now.
  20. The Following User Says Thank You to M-R-P For This Useful Post:
  21. #14
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    The drill or drill piece? The larger drill pieces kept jamming and the drill itself only cost me about £20.00.
  22. #15
    Another day,Another part. The
    Volvo pile is getting bigger
    Feb 2014
    Fleetwood lancs, uk
    72
    I loved this bit:
    "I then gave the sleeve a smack on the edge with the flat headed screwdriver and my hammer"
    LOL Back alley school of mechanics (I also went there)
  23. The Following User Says Thank You to soothingduck For This Useful Post:
    JamesT5 (Friday 14th March 2014)
