Page 3 of 3 FirstFirst 123
Results 41 to 56 of 56
  1. #41
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Quote Originally Posted by JamesT5 View Post
    I thought you didn't see the benefit to these types of filters.....
    He didn't want me to have it, so bought it out of spite.
  2. The Following User Says Thank You to stribo For This Useful Post:
    JamesT5 (Wednesday 12th March 2014)
  3. #42
    Trader
    Nov 2010
    chester le street
    969
    theres a huge difference between the elervate intake system and what your fitting james. for starters it needs to be bodged to fit and the route is terrible it will make air flow terrible. if you ever remove the intake pipe you realise wear the restriction is. the intake pipe gose down to around 1.5" near the turbo which is just stupid in my opinion.
  4. #43
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Quote Originally Posted by graemewelch View Post
    I don't agree with your comments at all. I happen to know a number of other members on here running exceptionally good performance figures using this Simota system. This system had been engineered and I'm sure PFV don't just stock any old crap that would make performance worse, nor make any false claims about the potential for increased power and performance. As Jamie has pointed out, the system won't be 'bodged' together, it just needs a little work and is superior to the set up I have now which in turn was superior to the original factory OE filter system.
  5. #44
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    I didnt want it as it was fitted to mine before as well.
  6. #45
    Trader
    Nov 2010
    chester le street
    969
    you missed out on a cracking bit of kit. sounds great and looks great.
  7. #46
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Didn't help your power figures on the rolling road.
  8. #47
    Trader
    Nov 2010
    chester le street
    969
    ive got rica to thank for that. What did yours get again
  9. #48
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    317.1, which I believe is more than you got. Just pulling your leg anyway mate, I'm sure it will be sorted with a different map.
  10. #49
    Trader
    Ready for the weekend
    partsforvolvos.com's Avatar
    Jun 2012
    Rainy Wellingborough
    270
    this simota kit is very similar to the bma 'cda' closed filter system that quite a lot of people in Sweden use. but the bma kit doesn't use a pipe to connect to the original cold air feed. you dost get a flexi section to duct the intake from.
    the only way I think the pipework could have been shortened with the simota kit is if they took the intake feed from the side of the round housing instead of the end, and then it could have fitted to the original intake with a much shorter route. other than that, there is not the room to do anything else if you want a closed system.
  11. #50
    Trader
    Nov 2010
    chester le street
    969
    i know mate. i was hoping o would of had my old map back on by now but just not enough time. ive got 9 spare days befor im out of action and swapping maps is right at the bottom of my list.
  12. #51
    Trader
    Nov 2010
    chester le street
    969
    here the pics to show the point i was trying to make last night. event he best airfilter is going to be usless with a intake pipe that reduced down to under 50mm. just think of it as a drink am mc donalds. you put a kink in the straw and what happens? youve got to work harder to suck it up. your turbo is exactly the same.
    an heres what i think is a much better route for the airfilfter
  13. #52
    Shiny Superstar
    Back in the game!
    Wobbly Dave's Avatar
    Aug 2004
    Stunning Shropshire
    2,501
    For what it is worth here's my 10p opinion.
    I agree with graeme to an extent - however it does depend on the turbo & the map and subsequently the amount of air - cubic feet per minute that you are trying to draw.
    You'd have to look at the flow map for the particular turbo in question to work that out. Luckily as we are mostly at sea level the pressure ratio will be unaltered.
    GIYF but there are some articles I've read before to help understand this nonsense
    From Garrett...
    http://www.turbobygarrett.com/turbob...ompressor_maps
    Once you've worked out how fast the air is going at maximum flat out suction - you'll need to know that above .4 mach air become turbulent & less efficiently flowed.
    I've also looked into that in some depth too.
    According to what I've read .4 mach is the speed at which air becomes turbulent & does not flow as well.
    2" piping
    1.57 x 2 = 3.14 sq in
    300 cfm = 156 mph = 0.20 mach
    400 cfm = 208 mph = 0.27 mach
    500 cfm = 261 mph = 0.34 mach
    585 cfm max = 304 mph = 0.40 mach
    2.25" piping
    3.9740625 sq in = 1.98703125 x 2
    300 cfm = 123 mph = 0.16 mach
    400 cfm = 164 mph = 0.21 mach
    500 cfm = 205 mph = 0.26 mach
    600 cfm = 247 mph = 0.32 mach
    700 cfm = 288 mph = 0.37 mach
    740 cfm max = 304 mph = 0.40 mach
    2.5" piping
    4.90625 sq in = 2.453125 x 2
    300 cfm = 100 mph = 0.13 mach
    400 cfm = 133 mph = 0.17 mach
    500 cfm = 166 mph = 0.21 mach
    600 cfm = 200 mph = 0.26 mach
    700 cfm = 233 mph = 0.30 mach
    800 cfm = 266 mph = 0.34 mach
    900 cfm = 300 mph = 0.39 mach
    913 cfm max = 304 mph = 0.40 mach
    Having the least number of bends is also more efficient - but I really don't see that the 16T is going to move enough air for the 50mm to be an issue.
    I think there will be other more pressing bottlenecks to overcome before this is an issue.
    Volvo ABS ECU Repair
  14. The Following 4 Users Say Thank You to Wobbly Dave For This Useful Post:
    claymore (Thursday 13th March 2014),Harvey (Thursday 13th March 2014),JamesT5 (Thursday 13th March 2014),M-R-P (Thursday 13th March 2014)
  15. #53
    Feb 2012
    135
    The simple thing is no matter what size feed pipe you have or what filter you have everything is governed eventually by the size of the MAF for calculating the air mass and also the CFM size of the turbo.
    Standard modified Airbox and filter are ok to about 400bhp so where does an aftermarket get you?........just an emptier wallet and noise!!.........Oh! and effort for nothing
    Now when talking N/A motors that is completely different and all the homework and effort that goes into induction routes from the front of the motor come into there own to keep the airflow up for performance a turbo engine will just purely rely on the suction of the turbo and grab what it can to cram in and will overcome any difficult obstructions the main hinderance being hot air which all these non enclosed type of filters give successfully........one main reason the standard air box is so good, as it`s all enclosed.
    Mercedes C320CDI Sport Estate 3 litre V6 7 Gear Auto
    Remap 290bhp 628Nm torque @ 1600revs 45.1mpg
  16. The Following User Says Thank You to 960kg For This Useful Post:
    graemewelch (Thursday 13th March 2014)
  17. #54
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    But you can't see it with the bonnet shut & it doesn't make any real difference and the seal to the bonnet is poor so it sucks in hot air from the engine bay.
    The best thing is to renew the stock air filter more often ,and there is no problem with putting oil on the filter that can get onto the MAF sensor.
  18. #55
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Quote Originally Posted by Pault5estate View Post
    Or like this!
    Did you ever get round to cutting the pipe to size ?.
  19. #56
    Blah Blah Blah!
    Volvostorm's Avatar
    Nov 2008
    Condover
    92
    Yeah, its been done now
