Results 1 to 11 of 11
    Liddo's Avatar
    Oct 2005
    Skelmersdale, Lancs
    341
    Knocking while braking after discs and pads replaced - non Volvo
    Hi All,
    Has anyone had this happen to them??? I replaced my daughters front discs and pads on her Fiesta 1.25 Zetec at the weekend.
    I used Pagid discs and pads from ECP and they went on really well and all seemed great...................until..........after about 15 mins
    of driving, whilst braking, a knock knock knock is now happening. I've stripped down the offending side again, and made sure everything
    is tight and sat right, but its still happening. The ONLY thing i didnt do is clean the new discs with brake cleaner. Could it be the pads
    gripping and releasing the discs???? Faulty pads??? Faulty discs??? Obviously there not warped as they are brand new.
    Any idea's???
    Thankyou, Goodnight....much love
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Make sure you've put the anti rattle spring on properly.
  3. The Following User Says Thank You to stribo For This Useful Post:
    Liddo (Monday 10th March 2014)
  4. #3
    trying hard to look busy!
    jdavis's Avatar
    Dec 2008
    Doncaster, South Yorkshire
    1,050
    What that man said^
    It's a 5 Cylinder Orchestra!
  5. The Following User Says Thank You to jdavis For This Useful Post:
  6. #4
    Liddo's Avatar
    Oct 2005
    Skelmersdale, Lancs
    341
    Yeah, I have done. It WAS a bitch to get off though, like it had never moved in 98k miles. Would that cause
    the banging??? It all seems very solid, nothing moves at all
  7. #5
    Apr 2012
    41
    Could it be a suspension bush gone?? Just coincidently after fitting pads/discs???
  8. The Following User Says Thank You to Rudeyboy18 For This Useful Post:
  9. #6
    Apr 2012
    41
    Or even loose wheel nuts
  10. #7
    Liddo's Avatar
    Oct 2005
    Skelmersdale, Lancs
    341
    Quote Originally Posted by Rudeyboy18 View Post
    Yeah, double and triple checked those. I was also thinking are they uni-directional pads or discs, but ive checked them out and there not. Might swap the mover anyway, to see if the fault swaps to the other side.
  11. #8
    Apr 2012
    41
    Process of elimination is a PITA. But rewarding " if " you find the fault
  12. The Following User Says Thank You to Rudeyboy18 For This Useful Post:
  13. #9
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    As a double check, this is how the springs should be fitted.
  14. The Following User Says Thank You to stribo For This Useful Post:
  15. #10
    Unbannable
    Jun 2012
    7
    what pads did you use if you used generic ones make sure there is no movement in the pad I had this issue with my old T5 as the place I got it from had just put generic cheap pads in that were slightly small and overtime the movement of them wore away part of the carrier. Didn't start making a noise till I'd had it for a year.
  16. The Following User Says Thank You to ExternalError For This Useful Post:
  17. #11
    Liddo's Avatar
    Oct 2005
    Skelmersdale, Lancs
    341
    Cheers chaps, and cheers Stribo for the pic, im 99.9% sure its fitted right, but i'll double check tomorrow
