And, as on my old 850R I found that the HT leads, dizzy cap, rotor arm were all the original items with manufacturer date stamps of 1997/8 ! Amazing that a car can run so well on 16 year old parts which were to be frank, utterly shagged. The dizzy cap and rotor arm were well worn as you'd expect, the HT leads... well I'll post some pics up soon - their condition probably explains the ocassional misfire!
So today I managed to change the cabin/pollen filter, spark plugs, HT leads, dizzy cap, rotor arm, air filter, and nearly all the vacuum hoses. Also rectified a few worrying discoveries - the LPG ECU was resting on the battery positive cable (again - weak bracket) and had started wearing the insulation, so thats been repositioned; the LPG regulator has dropped on its bracket and was resting on a brake pipe, nicely polishing it Various hoses were rubbing on each other and other items, various cables were stressed... the more I looked the more I found So all thats been rectified and fortunately no bits were left over - and the car runs beautifully smoothly again.
Just need to do an oil & filter change and a transmission flush, probably next weekend. Managed to squeeze it a quick boot & cabin vacuum & clean up, and found the jack - I thought it was missing. Instead it was under one of the smaller boot floor panels
So all in all a pretty good day. Still a lot of items to address, but nothing that you wouldn't expect from a 170k miler.
Off for a curry and a couple of pints now
TTFN
