Once the abs has been removed?
I gather the Volvo unit won't work, so I've been looking at gps units.
Any way of setting up analogue?
Current Chariots...
Micra K11 'project sh*tbox'
V70 D5 daily
1991 Transit Recovery
What year is the car? - Mike
95/96. On an N plate but can't remember exactly without looking.
Current Chariots...
V70 D5 daily
obd 2 takes the speedo reading from the Gearbox. so doesnt matter if you do away with the abs
AndysR (Saturday 1st March 2014),cherry1809 (Saturday 1st March 2014)
So how can I get round this?
How easy will it be to set up an obd1 set up?
Current Chariots...
V70 D5 daily
Bump.
Current Chariots...
V70 D5 daily
I use one of these, I don't know if you could tap into the signal from it.
http://www.ebay.co.uk/itm/2714310937...84.m1423.l2649
PIC][/SIGPIC]
aaaaaaaaaaaaaaaaaaaaaaaaa
cherry1809 (Monday 14th April 2014)
just wire the speedo directly to one of the ABS sensors, if your removing the ABS you can bin 3 of the sensors
ABS has already gone. So any sensor will run the speedo? Sounds easy so I expect it isn't. Lol.
Current Chariots...
V70 D5 daily
Yup, mine is piggybacked off the N/S ABS sensor, because I don't have a speed pick up in my gearbox now.
Doesn't seem to matter which colour wires you connect to the senor wiring either.
