Hello
I am in a nit of bother trying to locate a SMF for the Tdi. I have been searching around tinterweb and everyone says you cannot use t5 clutch and flywheel on a Tdi, my question is why not?
They are both 240mm with a 20 tooth spline, this is as much as i know so I am after info on input shaft diameter on the t5 and Tdi as i cannot find it anywhere. The only other measurement that may be different i guess is the thickness of the flywheel, But spacers or skimming could remedy this.
Cheers
