Page 1 of 6 123 ... LastLast
Results 1 to 20 of 105
    ...here we go again...
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Angry Boost hesitation and intermittent lack of power
    Right you lot!
    I have had the following fault code consistently reoccurring for the last 4 months with no symptoms: ECM6805.
    Turbo was replaced (as you all know) by the dealer a few months ago because my turbo seals were knackered and the car was burning tons of oil. After the Turbo was replaced I noticed the oil consumption was notably less and no more blue smoke off throttle (mainly after driving down a long hill). Boost was all good and seeing stable peak of around 15-16psi. Sweet!
    However, now I'm also getting fault code ECM130A and ECM6805. Now the symptoms are fluctuating base idle when warmed up, but it doesn't fluctuate all the time, mainly when you restart the car after its been switched off for 30 minutes or so. The idle is jumping around all over the place, hunting and it takes about 20 seconds to calm itself down.
    Also, when under hard acceleration in higher gears, ie 3rd or 4th it will "miss a beat" or jolt slightly, when boosting.
    Its really beginning to get on my wick.
    Before I take it to the dealer, cos that's likely at the moment, I wondered if anyway had any other ideas??
    Is my MAF knackered? The TCV was replaced only last week and it has made no difference. I have cleaned the BPS and I'm unable to log any live data because my poxy DICE will not communicate with the dam car!!!
    I'm at my wits end with the car at the moment cos I've been putting up with it for a while now, but the car drives 90% ok, most of the time!
    Any 'constructive' answers please would be much appreciated.
    Driving Miss Daisy
    V70 Graham's Avatar
    Feb 2012
    West London
    2,909
    It could well be the MAF Lee, I'm having fun as we speak.
    Take it out of its housing and give it a clean, I used 'Electrical cleaner' from Halfords @ £3.49 a can you can use half a can without bankrupting yourself, give it a good squirt from 8" or so and then let it dry out, repeat a couple of times, don't forget the temperature sensor on the side.
  3. The Following User Says Thank You to V70 Graham For This Useful Post:
    LeeT5 (Saturday 22nd February 2014)
  4. #3
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Sounds like it could be a MAF problem, but as you know mate, there are so many sensors without getting it plugged in, it's hard to pinpoint which one is playing up.
  5. The Following User Says Thank You to stribo For This Useful Post:
  6. #4
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Quote Originally Posted by V70 Graham View Post
    oooooooooooooooh, get the Volvo Master Technician.
  7. #5
    Driving Miss Daisy
    V70 Graham's Avatar
    Feb 2012
    West London
    2,909
    We all know I know very little lol but if I think what little I do know will help someone then I like to try and help out.
  8. The Following User Says Thank You to V70 Graham For This Useful Post:
    theflyingbrick (Saturday 22nd February 2014)
  9. #6
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    I know mate, just taking the pee.
  10. #7
    Feb 2012
    135
    Quote Originally Posted by LeeT5 View Post
    Right you lot!
    As you have changed the TCV the code may stay as you know perhaps for quite a few colds starts.....but if it doesn`t go are the hoses connected to it OK?...or are they blocked with crud etc......from a damaged turbo or otherwise?
    your other code as you probably know is for an air leak so seeing as the dealer changed the turbo has he damaged the PCV nipple or anything around that area to do with the PCV system to introduce an air leak ?....other than that maybe a damaged MAF!!..........is the irregular idle the common dirty or contaminated throttle flap??
    Mercedes C320CDI Sport Estate 3 litre V6 7 Gear Auto
    Remap 290bhp 628Nm torque @ 1600revs 45.1mpg
  11. #8
    sizzlechest's Avatar
    Mar 2005
    St Helens, Merseyside
    19
    Hi, try unplugging the MAF then taking her for a spin. It could rule out a dodgy MAF.
    2003 S60R. RaceS60R 3" DP, RaceS60R intake, Re-map performance remap, FMIC, D5 oil cooler
  12. #9
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,548
    how old is the fuel pressure sensor on the fuel rail? I believe they can throw weird codes when they fail.
    310.2bhp / 333ft/lb
    SOLD
    Got an old discovery now.
  13. #10
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    replaced by Volvo last year.
  14. The Following User Says Thank You to LeeT5 For This Useful Post:
    M-R-P (Sunday 23rd February 2014)
  15. #11
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Fuel pump or pumps as there are two in the tank,does it make any difference when you have a full tank as the second pump only works to transfer to other side ?.
    The pump controller have a look at the plug & socket as they can suffer from water ingress,it's near the fuel filter.
  16. #12
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Did the 2nd DiCE not work then ?.
  17. #13
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    No difference.
  18. #14
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Nope.
  19. #15
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Quote Originally Posted by sizzlechest View Post
    You cant do that on a P2 R. It needs the info from the MAF to correctly correlate boost pressure. Running without a MAF will just make it worse and cause lack of power.
  20. #16
    Sep 2013
    Portugal
    99
    My car will do the same occasionally, but no errors in the ECM... I know there is a small air leak in the charge pipe. Next month I'll be replacing the TCV, the vacuum lines and the ignition coils. Already left the car with the local dealer and nothing was found.
    The throttle body has been cleaned, the maf has been replaced, new spark plugs installed, new petrol filter, new timing and accessories belt fitted.
    V70 2.4T5 M66 Summum
  21. #17
    Kawasaki T5. Built by a Swede,
    Driven by a turnip!
    T5RatherAmusin's Avatar
    May 2013
    SW Wales
    303
    check for boost leakage dude
  22. #18
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Nope.
    So it does sound like software problem then.
  23. #19
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Update
    In the last week the car has been driving better. I am now seeing 12 psi of boost and it's gets there quicker, so maybe the new TCV is adjusting itself or rather, the ECM is learning and adapting. There is also less or almost no jittering under boost. All good! However, I'm still getting crap idle once warmed up, hunting and base idle fluctuating. It doesn't do this all the time just sometimes and it's very annoying. So, looking like it's more likely to be a MAF fault at the moment.
    Like I said, car is totally drive able just abit annoying when the idle starts going mental when sitting at traffic lights! As soon as I pull away, it's fine.
    Going to let dealer loose on it in a couple of weeks so we'll see what they say, assuming their DICE will communicate with the car. If it don't, then it looks like it will be having a new CEM.
  24. #20
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Lee, it's rare for you to ask others for advice on here, you're normally the guy waving all the answers at us and telling us where the garages have gone wrong. Interesting to see the opposite situation right now!
