Page 8 of 10 FirstFirst ... 678910 LastLast
Results 141 to 160 of 186
  1. #141
    Appreciative
    kmb's Avatar
    Oct 2014
    Suffolk & Rhone Alpes
    927
    I can confirm that oblark has perfected his mapping, he provided me with one of his mapped ECU's I requested a conservative and safe map, my 96 850 T5 has 136k miles just been fully serviced and ITG panel filter and Powerflow Stainless cat back exhaust, here are my findings after 200 miles with it fitted:
    Oblark put together a map which increases boost to 15 psi (from standard 9.6psi), the speed limiter stays at 160mph and boost limiter is 15psi... the car is considerably faster, and possibly smoother, which is a surprise. It is still very progressive with not too many traction control problems. It really flies on boost!
    The boost guage now goes to 90% max where as it was about 65%, engine was a little lumpy until it learnt, the lamba light also flashed on a few times in the first 20 odd miles but haven't seen it since.
    Nice to hear a bit more turbo whistle and it's certainly come alive.
  2. The Following 2 Users Say Thank You to kmb For This Useful Post:
    craigoodwood (Tuesday 23rd December 2014),oblark (Monday 22nd December 2014)
  3. #142
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,548
    He's a good lad is our Rob (if a little grumpy )
    310.2bhp / 333ft/lb
    SOLD
    Got an old discovery now.
  4. #143
    Appreciative
    kmb's Avatar
    Oct 2014
    927
    His communications were top notch and he seems a good egg.
    I've driven to work today in it instead of my boring 2014 A4 TDi, people think I'm crazy... the stainless exhaust burble is addictive so I'll use it tomorrow too!
  5. #144
    Jul 2011
    Poole, Dorset
    6,548
    Take the soundproofing off the bonnet
    310.2bhp / 333ft/lb
    SOLD
  6. #145
    Appreciative
    kmb's Avatar
    Oct 2014
    927
    Tempted but noooooo.
  7. #146
    Jul 2011
    Poole, Dorset
    6,548
    Quote Originally Posted by kmb View Post
    Booo...
    Drill the bottom of the air box too
    310.2bhp / 333ft/lb
    SOLD
  8. #147
    Appreciative
    kmb's Avatar
    Oct 2014
    927
    I was going for the mint and completely standard look, but with some under the bonnet hidden goodies, not Heath Robinson ghetto mods
  9. #148
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    You'll have to excuse MRP, he's a chav.
  10. The Following 2 Users Say Thank You to stribo For This Useful Post:
    Jamest5r (Monday 22nd December 2014),kmb (Monday 22nd December 2014)
  11. #149
    Jul 2011
    Poole, Dorset
    6,548
    310.2bhp / 333ft/lb
    SOLD
  12. #150
    VPCUK Car of the Year 2013
    Jim
    Jamest5r's Avatar
    Feb 2009
    Kangaroo land
    7,069
    And he makes a dam good job of it
  13. The Following User Says Thank You to Jamest5r For This Useful Post:
    stribo (Monday 22nd December 2014)
  14. #151
    My Car Will Never Be
    'Finished'
    Dan H's Avatar
    Mar 2013
    Stockton
    20
    I've also had my ecu mapped from a 2.5T LPT software and Rob whiped it and put t5 software and a map on it to go with my new t5 engine, I've not driven a standard t5, but the map on mine is really good! boost comes in smooth and keeps on climbing to around 16psi, and has out ran a few 'fast' things close to me, Need to get it on the rolling road after Christmas to what power it is pushing out!
    Would recommend Rob's services to anyone! Great Service
  15. The Following User Says Thank You to Dan H For This Useful Post:
    oblark (Tuesday 23rd December 2014)
  16. #152
    Ghost Rider
    If I want your opinion, I'll
    ask you to fill out the
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    Not done anything to this just a few fine tweaks to the map to get MPG better.
    I`ll be loading a bin file on the ecu at the weekend that takes the control of the fuel trim from the narrowband (lambda sensor) to the wideband. This means the AFR`s are more controllable.
  17. #153
    Gearbox Killer
    Proving the power of the
    15g....13.4@104.3mph
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    Quote Originally Posted by oblark View Post
    I'm looking forward to the next update, as I'm just in the process of going back though these 4.4 mapping and logging threads as I'm now in the position that I really need to start down this road with the next stages of olives development, just hope I understand it fully so I feel able to proceed.
  18. #154
    Member
    Oct 2013
    Rotherham, South Yorkshire
    0
    It makes a hell of a difference, a lot smoother. Ive gone back to narrowband control from WB control just to set up my 750cc injectors and its awful.
    1997 V70R FWD Manual
    608 Modded ECU with Ostrich 2.0, COP Conversion, ITG Filter, 3.5" MAF, 3" intake, 18t turbo, Do88 Intercooler, RIP, 3" TB, 750cc EV14 injectors, AEM 320 Fuel Pump, 3" Cat back, Spartan2 Wideband
    Lowered 40mm, Poly Subframe inserts
  19. #155
    Appreciative
    kmb's Avatar
    Oct 2014
    927
    I chanced upon a thread somewhere where someone was saying Air Con doesn't work if you stick a M4.4 in an 850, any truth in that Rob, didn't see the logic in it? I'm sure my air con still works fine even though my 850 is on your M4.4 ECU and map...
  20. #156
    Member
    Oct 2013
    0
    If you fit the ECU without changing 2 values in the bin, the AC won't work. At one time you had to do a hardware mod but recently, A very nice clever bloke called Piet from the Netherlands found a way to do it with no hardware mods
  21. The Following 2 Users Say Thank You to Avinitlarge For This Useful Post:
    kmb (Monday 4th May 2015),MoleT-5R (Friday 27th March 2015)
  22. #157
    Appreciative
    kmb's Avatar
    Oct 2014
    927
    Interesting, wonder if Rob has managed to do the same?
    I must admit I only used my A/C to clear windows on a wet day so am not yet 100% certain it works (also away for the next 3 weeks in France so cannot check yet)
  23. #158
    Member
    Oct 2013
    0
    Im not sure, I thought he had binned the A/C anyway?
  24. The Following User Says Thank You to Avinitlarge For This Useful Post:
  25. #159
    Appreciative
    kmb's Avatar
    Oct 2014
    927
    This was in reference to the ECU he mapped for me...
  26. #160
    Member
    Oct 2013
    0
    The soft mod only came to light 5th March, Not sure about the hardware mod. Either way, You have to do one or the other to get the AC working correctly of you convert from 4.3 to 4.4
  27. The Following User Says Thank You to Avinitlarge For This Useful Post:
