Page 4 of 10 FirstFirst ... 23456 ... LastLast
Results 61 to 80 of 186
  1. #61
    Unbannable
    Jun 2012
    7
    Quote Originally Posted by 960kg View Post
    I don`t understand the figures either ....but looking at it logically which this may be the reason for the wrong or expected figures!........
    The pic. of the 850R MAF the sensor part which reads the volume of air is in the centre of the MAF which it has to be to read the volume correctly also the design of the sensor with it`s thicker holder would of been calculated into the equation as it will effect the volume of air going past.
    The pic. of the BMW MAF holder with the Volvo sensor in, the sensor is not in the centre of the holder so therefore you won`t get a proper reading of volume!
    Also if you compare the Youtube pic. of the BMW MAF holder with it`s own sensor you will see although the pic. is on an angle the sensor is in the centre of the holder and is extremely thin to avoid any loss of volume of air going past and also will read the volume accurately.
    I think the reason it is lean is because the 850R sensor is off centre in the BMW holder and so it is only capable of reading less but more air is going past due to it`s diameter.
    Can you not use the BMW sensor or are the electrical ohms etc different or if you have a spare 850 sensor try modifying to go deeper into the holder to be central and also trim some plastic off it?
    Good Luck
    Could it have something to do with forced air hitting the sides of the MAF and causing pockets of turbulance which is why sensor is normally located at the centre. Not really sure but it seems to make sense in my head at least
  2. #62
    Feb 2012
    135
    Quote Originally Posted by oblark View Post
    I understand where you are coming from with the 850 sensor not being in the middle of the housing. The formula that I`m using with the maf editor software take in to account that the 850 sensor is not in the middle of the housing.
    When I moved the sensor even more away from the centre of the housing my kg/hr readings where closer to the values in the maf editor software.
    But that would make sense Rob as the more off centre the sensor is the more correct the MAF editor software readings are because as you say it allows for it!
    Quote Originally Posted by ExternalError View Post
    I don`t know but surely the larger BMW MAF is designed to work with it`s own more slender sensor in it`s centre......so really the nearer to the same shape as the original would be best, which is why i just suggested playing with the 850 sensor to allow it to get nearer the centre and also trim some plastic from it to make it more slender and as you say it would minimize turbulence of the measured air!
    One thing seems definite ......the sensor is not accurately measuring the volume of air going past as the mix is lean!
    Mercedes C320CDI Sport Estate 3 litre V6 7 Gear Auto
    Remap 290bhp 628Nm torque @ 1600revs 45.1mpg
  3. #63
    Randomly Typed Username
    Iraq Lobster
    jamesy12345's Avatar
    May 2013
    lives on Standard Row
    4,606
    The scaling for the 3.25" maf over the standard maf is 1.94 using the maf editor I`ve got. My one and only O2 sensor is brand new
    The scaling factor I mentioned was from here, page 10
    http://www.paerl.it/volvo/Volvo%20Motronic%204.4.pdf
  4. #64
    Member
    Oct 2013
    Rotherham, South Yorkshire
    0
    The BMW sensor is exactly the same as the Volvo one, the only difference is the plug. There are a number of people using this maf and table with no problems. Rob has a very odd issue. I would like him to get to the bottom of this, he has spent a lot of time on it. I can't see it, possible faulty ECU? I suppose its worth trying another.
    1997 V70R FWD Manual
    608 Modded ECU with Ostrich 2.0, COP Conversion, ITG Filter, 3.5" MAF, 3" intake, 18t turbo, Do88 Intercooler, RIP, 3" TB, 750cc EV14 injectors, AEM 320 Fuel Pump, 3" Cat back, Spartan2 Wideband
    Lowered 40mm, Poly Subframe inserts
  5. The Following User Says Thank You to Avinitlarge For This Useful Post:
    oblark (Sunday 20th July 2014)
  6. #65
    Ghost Rider
    If I want your opinion, I'll
    ask you to fill out the
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    Quote Originally Posted by Avinitlarge View Post
    I`ve sent my bin file to Maarten who is going to check it in HxD, I hope to god it`s not a ecu problem but I`m on the look out for another one to do the same mod that you`ve done
  7. #66
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    The maf upper & lower tables didn`t match, thats why the logged values didn`t match the values in the maf table.
    Thats that problem sorted on to the next, my LTFT_PL
    My LTFT_PL is @+29.69 which is way to high, I`ve tried all different values but with no joy.
    I know I was adding to much fuel as the car back fired everytime I changed gear.
    Will get they in the end
  8. The Following User Says Thank You to oblark For This Useful Post:
    claymore (Tuesday 22nd July 2014)
  9. #67
    VPCUK Car of the Year 2013
    Jim
    Jamest5r's Avatar
    Feb 2009
    Kangaroo land
    7,069
    Over run on.lift.off is good I say keep it, do you get flames?
  10. The Following User Says Thank You to Jamest5r For This Useful Post:
  11. #68
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    After going through a load of data logging, text files and xld files I thing I've found the problem.
    Now I dont want to tell how I've come to this conclusion as it is complicated and it will go straight over your heads
    but I need a new fuel filter.
  12. #69
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    Well I`ve changed the fuel filter and guess what still the same, So I`ve done some testing with different injectors/maf`s. The idea is to get the LTFT_PL to be as close to zero as posible on idle and while driving.
    Whites with 3.25 maf @ idle
    Whites with 3.25 maf driving
    Whites with stock maf @ idle
    Whites with stock maf driving
    So the problem looks like it`s the 3.25 maf/maf table. I`m going to send the white/stock maf bin file to Piet who is goin to convert it to run the 3.25 maf as something is wierd is going on with my maf table convertor software.
  13. The Following User Says Thank You to oblark For This Useful Post:
    MoleT-5R (Monday 28th July 2014)
  14. #70
    New Identity
    Dangerous Dave's Avatar
    Dec 2006
    West Midlands
    2,491
    Yep, seems that way.
    Hopefully Piet can get the right values for you.
  15. #71
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,548
    Still want the squirters checked Rob?
    310.2bhp / 333ft/lb
    SOLD
    Got an old discovery now.
  16. #72
    Cookie Monster
    its getting there
    theflyingbrick's Avatar
    Jun 2011
    east london
    1,820
    well at least you found whats bugging it up,good news
    full respray..plenty of body mods..comets..ray cat back noise pipe..decat and wrapped downpipe..me7 exhaust manifold..3" throttle body with ported inlet manifold..blue injectors..adjustable fuel reg..reverse intercooler pipework..19t..open cone air filter..255 fuel pump..m-r-p short shift..boost gauge..unknown remap..adjustable suspension..lightweight crank pulley..n/a cams..stripped out interior..and a heavy right foot
  17. #73
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    I`m holding fire on them at the moment, I`ll see what comes back about the maf table
  18. #74
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    On Piet`s recomemdation I`ve checked the sensor too housing fit.
    Sorry for the picture quality as they where taken on my phone.
    I discovered that the 850 (right) sensors o ring is 6mm from the flange and the BMW (left) sensors o ring is 10mm from the flange.
    Also the BMW maf housing has a 6mm deep chamfer whilst the volvo one only has a 2mm chamfer.
    BMW maf housing.
    Volvo maf housing.
    So the o ring on the 850 sensor is not sealing againt the BMW housing as it sits where the chamfer is, to overcome this little problem I`ll get a thicker o ring tomorrow from work.
    Then I`ll refit the maf with Piet`s bin file.
  19. The Following 2 Users Say Thank You to oblark For This Useful Post:
    Dangerous Dave (Monday 28th July 2014),theflyingbrick (Monday 28th July 2014)
  20. #75
    New Identity
    Dec 2006
    West Midlands
    2,491
    Hmm, so it may be leaking then
  21. #76
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    Quote Originally Posted by Dangerous Dave View Post
    It looks like it could of been, but only slightly.
  22. #77
    Cookie Monster
    its getting there
    Jun 2011
    east london
    1,820
    slightly would be enough to cause grief on a standard tune so i reckon itll cause havoc on yours!!
  23. #78
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    The o ring on the 850 sensor is 3mm, so I`ve fitted a 4mm and its sealed the sensor to the housing.
    The first picture is the 850 o ring and sensor, the second picture is the with the 4mm o ring, it pulled in nicely when the screws where done up.
    I`ll go for a drive later on once the rush hour traffic has died down and report back
  24. The Following User Says Thank You to oblark For This Useful Post:
    claymore (Tuesday 29th July 2014)
  25. #79
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    Loaded the bin file Piet checked for me and result one happy bunny
    Here two screenshots first is at idle and the second one is driving.
  26. #80
    Cookie Monster
    its getting there
    Jun 2011
    east london
    1,820
    wow thats a big difference!! just a little leak huh? glad you sorted it mate
