Page 10 of 10 FirstFirst ... 8910
Results 181 to 186 of 186
  1. #181
    Ghost Rider
    If I want your opinion, I'll
    ask you to fill out the
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    After having the car MOT'd on monday I've keep getting the fault code of EFI-233.
    Name:  25-12-15-fault codes.jpg
    The first 2 are not worth worrying about but the EFI-233 adaptive idle air trim is the one that is putting the lambda light on. So with a bit of research on the internet I came across this.
    "Diagnostic trouble code (DTC) information EFI-233
    Substitute value idle air trim disabled fuel shut-off conditions changed output signals to the coils are regulated with a fixed value depending on the cause of the fault leakage diagnostic is disabled. Possible source
    Signal too high: short-circuit to supply voltage in the signal cable defective idle air control (IAC) valve.
    Signal too low: opening and closing coil signal cables short-circuited to each other defective fuse 11B/2 (1998-) open-circuit in power cable short-circuit to ground in signal cable defective idle air control (IAC) valve contact resistance in terminals.
    Signal missing: open-circuit in signal cable defective idle air control (IAC) valve contact resistance in terminals.
    Fault symptom[s] idling speed low or high."
    As I'm not getting a signal to low/high or missing I'm little puzzled on what the fault could be as the IAC has been running trouble free years.
    So rooting around in the Bin I came across a RPM/throttle angle boundary for ZWD off (IAC valve) as you can see in standard form the IAC is still in use upto 3390rpm and 47.30 degrees on the throttle. So I've lowered both values to 1980rpm and 19.98 degrees on the throttle.
    I'll upload the new values on the ECU tomorrow and see what happens.
  2. The Following 2 Users Say Thank You to oblark For This Useful Post:
    jamesy12345 (Thursday 26th November 2015),Saaamon (Friday 27th November 2015)
  3. #182
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    The new values for the IAC where uploaded to the ECU and the lambda light hasn't stayed off
    As I've stopped the engine knock at 15 psi so I turned the boost up a bit
    It looks like shes running a little rich with some slight knock, 22 psi @ 3690 rpm, not bad for standard rods.
    I've adjusted the TCV load and duty cycle so the maximum boost comes in @ 4500 rpm
  4. #183
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    Did a bit more this weekend on getting the injectors dialed in.
    Brown line - requsted AFR
    Light blue line - actual AFR
    At idle
    Driving at 40 mph
    Well atleast now I know what to do when I set up my 750cc injectors up
  5. #184
    Jul 2008
    126
    Quote Originally Posted by oblark View Post
    I would'nt push the timing much further and I'd reduce the boost a bit mate, rich and knocking isn't good at low RPM. I can't read your screens though but as you know you want a nice smooth torque curve on stock rods
  6. #185
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    Quote Originally Posted by Dream3r View Post
    I was running the car on normal unleaded fuel, I'm now runnning on Esso super unleaded and not getting so much knock.
    Here is ignition map I'm running/tweaking at the moment
  7. #186
    Jul 2008
    126
    That's quite high lol does it achieve it?
    95 octange is bad for these man I seen an R pull 15 degrees on 95 Ron lol.
    Tesco 99 rules
There are currently 16 users browsing this thread. (0 members and 16 guests)
