GOOD .......is the only operative word to use as i have had three different mech. boost guages and they all read about +7psi out even on idle -30mHg....also one reading up to +20psi the needle will not go over but it hits a stop so you could be boosting 25!!!
I was getting pretty peed orff keep sending them back so opted for a Digital one which reads to calibrate and sets every time you start the engine.....quite handy also as it gives battery voltage for 20secs before it goes over to boost mode.
Avoid "Aggressive Guages"
Also my Torque app. read 135 degrees on the coolant temp. and my temp. guage was normal with no fan going and it is a newish sensor!
Anyway i don`t bother with any reading etc. more to worry about!.......all the time it goes ok i leave alone except of course when adding more performance items...
Mercedes C320CDI Sport Estate 3 litre V6 7 Gear Auto
Remap 290bhp 628Nm torque @ 1600revs 45.1mpg
M-R-P (Saturday 15th February 2014)
which digital gauge did you get Keith? Fed up with mime reading 20psi when it's clearly not lol.
310.2bhp / 333ft/lb
SOLD
Got an old discovery now.
Got this one Martin....mine reads for psi, probably can get better but it is superb .....you get all the bits with pressure sensor etc. easy to fit......mine is wired to the light switch so i can interupt the voltage supply and the guage goes to battery condition or charging rate for 20 seconds before going back to boost condition......in otherwords you can see what the alternator is chucking out!.....with blower on or off or whatever!
M-R-P (Saturday 22nd February 2014)
Had a play around with the Torque app and set it up.. Got a few screen shots.
Hope that intake temp isnt right at 50C..
Fuel pressure is a bit far out.
Maybe i didn't set it up right.
Just asking, I can remember seeing a reader that used a AV out signal so you could use a in car screen, anyone knows if you can still get it.
