Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21
    ...here we go again...
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Tried another (known working) DICE. Same symptoms. No difference.
  2. #22
    Norfolk born and bred.
    Give me a high 6!!!
    silverhorse's Avatar
    Oct 2012
    Great Moulton Norfolk NR15
    221
    Quote Originally Posted by LeeT5 View Post
    Bugg3r.
    I sense a wallet lightening session coming on.
    Me: 2005 V70 2.4 T5 SE. All standard.
    The Wife: 2008 C70 2.5 T5 SE. All standard.
  3. #23
    trying hard to look busy!
    jdavis's Avatar
    Dec 2008
    Doncaster, South Yorkshire
    1,050
    Is the .net Framework version correct? If I remember right it needs to be 3.5.
    Also have you checked the USB port with something else?
    Any one near you that can use your dice on their Vida?
    It's a 5 Cylinder Orchestra!
  4. #24
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Quote Originally Posted by jdavis View Post
    Mmmm, interesting. Well I don't know about .net framework Ver, but I can tell you that it was all working fine before xmas and the laptop then had ALL the latest windows 7 updates installed, which I'm assuming will mean the latest Version of .net Framework. That is version 4.5 (I think). So, I can't see how that would affect it?
    All the USB ports work fine.
    No - to local request (or they're all hiding!).
  5. #25
    Feb 2012
    135
    I haven`t read all the posts but Vida wil only work on Windows XP 32bit or Windows 7 Professional as this uses both XP or 7 at 32bit or 64bit
    It will not run in Windows 7 Premium in compatability mode either only the earlier Vadis will!
    Manufacturers only seem to use the older XP 32bit .....Vauxhall do as well as i can`t load there`s to run.
    You can load winXP onto the other portion of the drive that the main OS is on and then load Vida.
    It is best to let Vida have it`s own stand alone computer/laptop with it`s own working OS if used just for motor problems.
    Also one has to use IE8 or Google Chrome or Firefox.........and this is the main culprit ...if Windows update has allowed IE9 or IE10 to be loaded even though you use Firefox or the others IE9 will not allow Vida or Vadis to run because of its`s components are loaded on the computer......One has to Delete IE9 or IE10 completely to allow Vida/Vadis to be used. The programs may load on 32bit but the functions or options will not open.
    This all may help or it may not!.............Good Luck.
    Mercedes C320CDI Sport Estate 3 litre V6 7 Gear Auto
    Remap 290bhp 628Nm torque @ 1600revs 45.1mpg
