Page 8 of 8 FirstFirst ... 678
Results 141 to 148 of 148
  1. #141
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Quote Originally Posted by graemewelch View Post
    I cant see how you can prove that the garage was to blame. More likley it was a faulty part. If the clutch isnt fitted correctly then it wouldnt work. The fact that i didnt fail for months says to me that your clutching at straws. The work was done under warranty so i dont understand the fuss
    I have evidence I can't show you that indicates faulty installation.
  2. #142
    Trader
    Nov 2010
    chester le street
    969
    That is intresting cause expierence tell me otherwise. Theres only a few things you can do you wrong. Fit a clutch to a worn/used dmf. Fit the bearing the wrong way around. Impossible on the volvo. Fit the cluch plate the wrong way around, again clutch wouldnt work. Not preload the pressure plate this would just wear out the clutch plate faster. Not torque the pressure plate correctly. Youd feel it in the pedal if it came loose. Not aline the clutch plate. If the gearbox fits then its aligned. Id love to see this evidence cause i still dont beleave the garage is at fault and its a cause of blaming anyone regardless of it being there fault. This of course is just my opinion and untill theres facts to proce me wrong then my opinion wont be changing
  3. The Following 2 Users Say Thank You to graemewelch For This Useful Post:
    LeeT5 (Sunday 27th April 2014),MIKESC70T5 (Thursday 24th April 2014)
  4. #143
    Gold 'N' Brown's Avatar
    May 2013
    Edinburgh
    15
    Baddaboom-tsch
    2001 V70 T5 (Manual) - The Turnip
    1999 9-5 Aero (Manual) - Sven
  5. The Following 2 Users Say Thank You to Gold 'N' Brown For This Useful Post:
    graemewelch (Thursday 24th April 2014),M-R-P (Thursday 24th April 2014)
  6. #144
    Trader
    merc85's Avatar
    Sep 2010
    Harwich Essex
    4,987
    I had a customer fit the clutch plate the wrong way round and it punched the centre of the plate straight out, Also ive had one recently where a 2009 Mondeo diesel clutch was fitted not using the self adjusting clutch tool,(SAC) this caused clutch judder almost immediately after fitment.
  7. The Following 2 Users Say Thank You to merc85 For This Useful Post:
    graemewelch (Thursday 24th April 2014),JamesT5 (Thursday 24th April 2014)
  8. #145
    Trader
    Nov 2010
    chester le street
    969
    Quote Originally Posted by merc85 View Post
    Exactly what im saying gav. If its fitted wrong it just wont work. Mistakes do happen when they are fitted but you know instantly that its wrong
  9. #146
    Feb 2012
    135
    First of all great news that your all done and the motor is back and on the road.
    This lining up thingy!........again most are talking the incorrect language as now there are various versions of clutches ...some don`t automatic adjust.... and some do!
    On the auto.adjust ALIGNING the counterhold with a special tool has to be used to enable automatic clutch adjustment.......there are levers with springs that go in slots etc. that all have to be aligned correctly...so is it this that Sachs say has not been done properly?
    A CENTRALISING tool is the method used so as the gearbox goes on through the clutch splines ok and not ALIGNMENT.
    As far as i know through out my motoring life of replacing engines and gearboxes the word has always been ......."get the clutch centralised"
    You are centralising the clutch plate and not aligning it!
    Mercedes C320CDI Sport Estate 3 litre V6 7 Gear Auto
    Remap 290bhp 628Nm torque @ 1600revs 45.1mpg
  10. #147
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Quote Originally Posted by 960kg View Post
    I can remember this tread about S60R/V70R clutch fitting.So is the T5 the same set up ?.
    You need a tool to reset the ratchet mechanism within the pressure plate mechanism.
    This makes interesting reading this link.
    http://forums.swedespeed.com/showthr...tall-headaches
  11. The Following 2 Users Say Thank You to Harvey For This Useful Post:
    960kg (Thursday 24th April 2014),merc85 (Thursday 24th April 2014)
  12. #148
    Trader
    Nov 2010
    chester le street
    969
    yes harvey the t5 is the same set up. the pressure plate can be reset on a bench using two screw drivers. then fit the pressure plate. even if this hadnt been done to james car when the new clutch was fitted it still wouldnt of failed the way it did. it just would of ran out of adjustment sooner and would burn out faster. but not fall apart.
