Page 1 of 8 123 ... LastLast
Results 1 to 20 of 148
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Exclamation Half way to work and...... Jolt!
    The clutch failed!
    I was approaching a junction to turn right, de-clutched and there was a 'jolt' through the clutch pedal and I couldn't engage 1st gear (or any other gear for that matter). So I managed to get in to the right hand turn, rolled it down a hill and pulled in to a local school driveway and called the AA. The car would not engage any gear but would 'creep' forward when I pushed the gear stick against the gear selector, I know that gearbox is working on and it is clutch related.
    The AA man turned up and plonked some clutch fluid in and pumped the clutch to see if it could be a leak in the slave cylinder, then pumped the clutch pedal but it made no difference.
    Then I had to wait for another AA man to come out and tow me home. Whilst waiting for him I turned the engine off for a bit and then tried restarting it but it struggled massively to fire up, and was 'chugging' around 500 rpm. The throttle was non-responsive although the engine was running but what really shocked me and is quite worrying is that the engine temperature slowly creeped right up towards the higher end of the scale on the needle. Why would it do this? Surely engine temperature has nothing to do with the clutch? I turned the engine off and the engine cooled down but I don't know how this relates to clutch failure and just to clarify, the engine temperature had not creeped up before the clutch failure.
    Either way I'm now totally stuck, all this hard work and now this. Personally I think the garage who installed the clutch and gearbox for me may have made a serious installation error and I'm considering having the car taken on a flat loader to GRN to see if they can sort it for me.
    One consolation, I have garage repair cover on my AA policy, at least that should ease the burden!
    I'm moving house this week as well, could the timing of all this be worse on top of the fact that I was on my way to work and I've lost a shift tonight because if it.
    Jul 2008
    2,869
    Dual mass flywheel failure....?
    Gun Metal Grey - Volvo 850R - Saloon
    Thanks to Russ and team www.rtmechanics.co.uk
  3. The Following User Says Thank You to AndysR For This Useful Post:
    JamesT5 (Sunday 26th January 2014)
  4. #3
    Swollen Member
    stephenevans99's Avatar
    May 2006
    1,487
    It Never Rains James.....like we said at the Two Henry's meet, sometimes it feels like 1 step forward and 2 steps back. I feel your pain mate.
    I honestly can't understand why a clutch failure would effect the engine cooling.....BUT it is a P2
  5. The Following User Says Thank You to stephenevans99 For This Useful Post:
  6. #4
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    There is absolutely no way I'm going to gloat, I really feel for you
    PIC][/SIGPIC]
    aaaaaaaaaaaaaaaaaaaaaaaaa
  7. The Following User Says Thank You to claymore For This Useful Post:
  8. #5
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,548
    Have you had a look at the gearbox James? just wondering if a pipe or bit of wiring loom has dropped and got tangled up with the gear linkage.
    Long shot I know but there's coolant pipes and a lot of cables running a couple of inches away from the shift arm.
    310.2bhp / 333ft/lb
    SOLD
    Got an old discovery now.
  9. The Following User Says Thank You to M-R-P For This Useful Post:
  10. #6
    Meh.....
    Biff's Avatar
    Dec 2012
    Wrecsam North East Wales
    2,528
    Bad day for both of us James! Hope it's sorted for you soon, we both have had a lot of bad luck!
    missing being Swedish
    Previously:
    03 S40 Sport Lux 1.9d SOLD
    1998 V70R AWD Manual BROKEN
  11. The Following User Says Thank You to Biff For This Useful Post:
  12. #7
    Trader
    merc85's Avatar
    Sep 2010
    Harwich Essex
    4,987
    what make was the clutch and flywheel out of interest?
  13. #8
    Jul 2011
    Poole, Dorset
    6,548
    Quote Originally Posted by merc85 View Post
    iirc, both genuine volvo but the flywheel was 2nd hand.
    310.2bhp / 333ft/lb
    SOLD
  14. The Following User Says Thank You to M-R-P For This Useful Post:
    merc85 (Sunday 26th January 2014)
  15. #9
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Yes, it was a LuK clutch and I had a new slave cylinder as well.
  16. The Following User Says Thank You to JamesT5 For This Useful Post:
  17. #10
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Quote Originally Posted by AndysR View Post
    Well, obviously can't rule it out but if it is then I have a massive amount of ammunition against the company that sold it to me.
  18. #11
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Incidentally, there is no coolant loss (reference the engine temperature).
  19. #12
    Trader
    merc85's Avatar
    Sep 2010
    Harwich Essex
    4,987
    Quote Originally Posted by JamesT5 View Post
    was is sold with a guarantee then??
  20. #13
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    Quote Originally Posted by Biff View Post
    I did notice you've posted a thread up about a suspected bent rod. Annoying and worrying when stuff like this goes wrong, isn't it!
  21. #14
    Jul 2008
    2,869
    Well if the flywheel was new then you'd have a guarantee so you may not need to enter into an argument with those that fitted it, if it's a second hand item and all appeared well when fitted then I doubt you'll have much comeback. If the flywheel has failed and it's knocking the engine management may just be interpreting the knock as misfire/det and retarding the timing which may explain your temperature issue
  22. #15
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    As you know from running a business of your own Gav, the Sale of Goods act will cover me in that the goods sold must be of satisfactory quality and be fit for purpose. If it has failed, it will be obvious that the part wasn't.
  23. #16
    Trader
    merc85's Avatar
    Sep 2010
    Harwich Essex
    4,987
    Ive got to be totally honest i dont know if the "Sale of goods act cover's 2nd Hand items" thats why i was enquiring, and also why anything i sell threw my Business is "New" and also comes with the Manufacturer's guarantee.
  24. The Following User Says Thank You to merc85 For This Useful Post:
  25. #17
    Trader
    Nov 2010
    chester le street
    969
    your not going to want to hear this but a worn dmf is probobly the cause. the garage that done the work will prob say they advised the dmf should of been replaced to. even if it is the clutch that has failed theres a very good chance that its the excessive play in the dmf thats caused it. hope you get it sorted with out costing you to much
  26. The Following User Says Thank You to graemewelch For This Useful Post:
  27. #18
    Banned
    Circle of a Bus.
    May 2012
    Mid Wales
    1,529
    It does cover second hand items mate.
  28. #19
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Sorry to hear this James hope it not to painful on the wallet, it does sound like DMF but the overheating pass on this.
  29. The Following User Says Thank You to Harvey For This Useful Post:
  30. #20
    Trader
    merc85's Avatar
    Sep 2010
    Harwich Essex
    4,987
    thats cool then bud, i just didnt know. But i do now.
  31. The Following User Says Thank You to merc85 For This Useful Post:
