Page 1 of 2 12 LastLast
Results 1 to 20 of 30
    Lawnmower Boy
    Now known as WAPAHO!!!
    JUDGENINJA's Avatar
    Nov 2004
    Guildford, Surrey
    1,058
    Best place for turbo copper washers...?
    I bought a cheap box of was from Halford thinking that a box with random sizes would do, but no.....
    I'm bolting up all the oil/water cooling pipes on the S40 so need to find the right size rings. I could pop to Volvo and guarantee to get the right sizes, but I shouldn't need to.
    Easy question for the knowledgeable, are the washer sizes taken from the internal or external sizes?
    Current Garage:
    *Data Sept 2013
    5 pot heart of a Volvo
    T5frankie's Avatar
    Apr 2006
    On the strip
    4,423
    i bought the same washers and their is a size in that box that fits perfectly on a t5 anyway
  3. The Following User Says Thank You to T5frankie For This Useful Post:
    JUDGENINJA (Tuesday 21st January 2014)
  4. #3
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Quote Originally Posted by T5frankie View Post
    Do they do a Imperial set and metric set ?.
    Just looked on screwfix site.
    http://www.screwfix.com/p/copper-was...0-pieces/18756
    http://www.screwfix.com/p/heavy-wash...k-of-800/32406
  5. The Following User Says Thank You to Harvey For This Useful Post:
  6. #4
    JT's Avatar
    Jun 2010
    sussex
    1,641
    Quote Originally Posted by JUDGENINJA View Post
    I'm told internal
  7. The Following User Says Thank You to JT For This Useful Post:
  8. #5
    T5frankie's Avatar
    Apr 2006
    On the strip
    4,423
    not that i noticed, these are metric,
    its the 4th ones up iirc
  9. #6
    Lawnmower Boy
    JUDGENINJA's Avatar
    Nov 2004
    Guildford, Surrey
    1,058
    Thanks I'll have a look at those. For some reason they fit the single bolt that goes into the block, but not the turbo end.
    Another question - Can I get the flat flange exhaust gasket from anywhere?
    Current Garage:
    *Data Sept 2013
  10. #7
    Trader
    Nov 2010
    chester le street
    969
    if youve got the old ones. heat them up untill there glowing orange and let them cool down. they be useable again. dont be tempted to quench them though as it wont work.
  11. #8
    Lawnmower Boy
    JUDGENINJA's Avatar
    Nov 2004
    Guildford, Surrey
    1,058
    Unfortunately they are lost so I need to get new ones.
    Current Garage:
    *Data Sept 2013
  12. #9
    T5frankie's Avatar
    Apr 2006
    On the strip
    4,423
    You don't need a gasket for the flange, but I think they are listed for the v70r's not 850's
  13. The Following User Says Thank You to T5frankie For This Useful Post:
    JUDGENINJA (Wednesday 22nd January 2014)
  14. #10
    Gearbox Killer
    Proving the power of the
    15g....13.4@104.3mph
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,798
    If it's anything like the 850, they are different sizes at each end of the pipe, only just found this out when I picked up my new pipe and fittings from the local steeler the other week
  15. The Following User Says Thank You to MoleT-5R For This Useful Post:
  16. #11
    Trader
    Ready for the weekend
    partsforvolvos.com's Avatar
    Jun 2012
    Rainy Wellingborough
    270
    there are 2 different sizes of washers. 947282 and 947621 ring a bell. I used to be able to just order turbo fittings full set off the top of my head !- how sad I just checked on vida and that is correct
  17. The Following User Says Thank You to partsforvolvos.com For This Useful Post:
  18. #12
    Lawnmower Boy
    JUDGENINJA's Avatar
    Nov 2004
    Guildford, Surrey
    1,058
    Thanks all, I'm going to risk a trip to Halfords again for the box Frankie suggested before I panic and go to Volvo.
    Frankie - yes this gasket seems to only be a shim between the two surfaces, so I might chance it..
    Current Garage:
    *Data Sept 2013
  19. The Following User Says Thank You to JUDGENINJA For This Useful Post:
    T5frankie (Wednesday 22nd January 2014)
  20. #13
    Lawnmower Boy
    JUDGENINJA's Avatar
    Nov 2004
    Guildford, Surrey
    1,058
    Ok - Halfords is OK for the smaller washer, but no good for the larger one for the block.
    I measured them this evening they are 12mm ID and 14mm ID.... I could be off to Volvo at this rate..
    Current Garage:
    *Data Sept 2013
  21. #14
    no experience but has
    enthusiasm aplenty
    Aug 2013
    norwich
    239
    Loads of 12mm and 14mm I/d on evilbay
    http://item.mobileweb.ebay.co.uk/vie...d=310331946496
  22. #15
    Wiping smiles off faces!
    Dec 2013
    Portsmouth
    87
    I couldn't find anywhere else but Volvo who did the gasket
  23. #16
    Lawnmower Boy
    JUDGENINJA's Avatar
    Nov 2004
    Guildford, Surrey
    1,058
    Quote Originally Posted by artfulflounder View Post
    Thanks and bought...
    Quote Originally Posted by RichT4 View Post
    Yep, looks like it is a dealer only part.... If I can stomach another drive over to Volvo I still might have time to get one.
    This must be the longest job ever just to refit a turbo!!
    Current Garage:
    *Data Sept 2013
  24. #17
    Dec 2013
    Portsmouth
    87
    I know mate, took me 3 attempts to get everything right. Volvo had given me the wrong part as well!
  25. #18
    enthusiasm aplenty
    Aug 2013
    norwich
    239
    Found summit racing in states have them....I know but manufactured by walkers exhausts.
    the local uro to me is a walkers distributor so maybe if you found a walkers stockist local to you they would stock one?
  26. #19
    Feb 2012
    135
    I still do not understand why owners go to other places for such important parts which probably will cost more than the quality parts from Volvo?
    A phone call with your Reg. number and the part you need pick up next day for peanuts.......that is what i did when i fitted an 18T , fitted in two days done and dusted!
    Mercedes C320CDI Sport Estate 3 litre V6 7 Gear Auto
    Remap 290bhp 628Nm torque @ 1600revs 45.1mpg
  27. #20
    T5frankie's Avatar
    Apr 2006
    On the strip
    4,423
    Quote Originally Posted by 960kg View Post
    a coper washer is a copper washer keith, not everyone has a volvo dealership in their town, my nearest volvo dealership is 20 miles away
