Results 1 to 18 of 18
    Member
    Old school affair
    Jul 2011
    21
    Volvo s60 t5 auto gearbox problems
    hello i am a bit gutted as after replaceing my auto gearbox on my car, its not engageing gear again for more 10 seconds again, which exactly what was wrong with it b4.
    When i first fitted the gearbox it drove excellently for a good 20 miles and then i parked it up then i went back to it a few days later and the same problem occurred,,,
    Attached Images Attached Images
    Ghost Rider
    If I want your opinion, I'll
    ask you to fill out the
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    The chances of 2 auto boxes have the same fault is rare,
    Does the S60 have a auto ECU ? if so this could be the fault.
  3. The Following User Says Thank You to oblark For This Useful Post:
    c30don (Wednesday 15th January 2014)
  4. #3
    Member
    Old school affair
    Jul 2011
    21
    i was thinking that but the mechanic said he plugged his snap on diagnostic machine in and it came up with nothing...... do you know how many litres of atf it takes? someone told me it was eleven , but on the auto data app it saying 3 i am confused
  5. #4
    Ghost Rider
    necessary forms
    oblark's Avatar
    Jul 2005
    Romsey, Hampshire
    982
    Quote Originally Posted by c30don View Post
    I haven`t got a clue on the amount of oil it takes to fill a auto box,
    But 3 doesn`t sound enough.
  6. The Following User Says Thank You to oblark For This Useful Post:
  7. #5
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Have you had the gearbox codes looked at.
    Did you use the correct fluid in the box,do you have the correct level in the box cold & when hot,is the oil cooler in the rad clear oil is flowing ok.
    Try the cars fault code reader to see if there a code loged for the gear box
  8. The Following User Says Thank You to Harvey For This Useful Post:
  9. #6
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    The box needs 9 liters or so have you checked the level with the dipstick at the front of the box ( its yellow).
    The level is checked with the engine running after you have gone throught all the gears 10 sec in each gear twice engine ticking over.
  10. The Following User Says Thank You to Harvey For This Useful Post:
    c30don (Thursday 16th January 2014)
  11. #7
    Beer Baron
    LiamT4's Avatar
    Jan 2010
    Leicester
    1,849
    According to the manual for my 2004 s60 2.0t auto, its 7.2 litres and makes no distinctions between engine variants.
  12. #8
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Do you know what type of fluid you put in the box.
  13. #9
    Beer Baron
    LiamT4's Avatar
    Jan 2010
    Leicester
    1,849
    Correct stuff according to my manual is AW55-51, AW55-50 and the grade is JWS 3309.
  14. #10
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Quote Originally Posted by LiamT4 View Post
    Yep 3309 is correct but that's not a standard ATF that you get from most factors.
  15. #11
    trying hard to look busy!
    jdavis's Avatar
    Dec 2008
    Doncaster, South Yorkshire
    1,050
    Is it a full auto or geartronic?
    It's a 5 Cylinder Orchestra!
  16. The Following User Says Thank You to jdavis For This Useful Post:
  17. #12
    Member
    Old school affair
    Jul 2011
    21
    its a geartronic,,,,,,
  18. #13
    Member
    Old school affair
    Jul 2011
    21
    well i have flushed the old fluid out and put the new fluid in and the car is still the same.....f luid cost me a fortune so i aint a happy bunny, another gearbox is like £300-400 can anyone help me please
  19. #14
    Member
    Old school affair
    Jul 2011
    21
    i am breaking this car now ,,, had enough ... will put a price list together and then post the list .........BLOODY CRYING SHAME......
  20. #15
    jdavis's Avatar
    Dec 2008
    1,050
    Is the fluid level OK? When you fitted the new box did you do an adaption? B4 servo been replaced? Software up to date?
    I'm guessing it is 3rd gear
  21. The Following User Says Thank You to jdavis For This Useful Post:
    c30don (Monday 17th February 2014)
  22. #16
    Member
    Old school affair
    Jul 2011
    21
    yes the fluid is all ok, even my friend at volvo mania had it on his computer and no code faults were found ..... i really cant spend another penny on it as i am already ready in the dog house ... so rather than lose altogether i rather get back some of my money.. thanks for your input anyway
  23. #17
    jdavis's Avatar
    Dec 2008
    1,050
    I know you said you don't want to spend another penny but have codes been read with Vida?
  24. #18
    Member
    Old school affair
    Jul 2011
    21
    hello , I am not sure what program code reader they used , bit too late now as i have already started to break it up ,jjust the running gear and back axle beam left....... Thanks again, i will seek your advice next time i run into a problem with a volvo ......... Hope you dont mind ..
    KEEP ON VOLVO ING
