Page 1 of 3 123 LastLast
Results 1 to 20 of 41
    Member
    Rover Turbo Nutter
    Vard66's Avatar
    Jan 2014
    Near Marlborough, Wilts.
    11
    Bluetooth Adapter issues - '96 850R.
    Hey guys.
    Just had a quick search but I can't seem to find anyone else having any grief with bluetooth adapters like I am.
    I bought an ELM327 bluetooth adapter several months ago to try to access the codes and service light wipe option in the ECU on my '96 850R using Torque Pro on my HTC Desire HD, but while I can connect the phone to the adapter fine, I cannot get the adapter to communicate with the ECU.
    Since then I have tried several other different (non cheapy blue eBay job) bluetooth adapters in conjunction with Torque, and I'm encountering the same issue every time.
    Anyone have any pointers?
    Cheers,
    Vard
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,548
    go into the torque settings and under adaptor settings, look foe "choose Bluetooth adaptor" and select your device. then restart the app.
    job done
    310.2bhp / 333ft/lb
    SOLD
    Got an old discovery now.
    Member
    Rover Turbo Nutter
    Vard66's Avatar
    Jan 2014
    11
    Tried that. Have also tried scanning for protocols, nada. :/
    My first thought was that it must be a bad adapter, there's a lot of people who state that the cheap blue ones you find on eBay are badly made or don't have the right protocols, but I've tried two or three more expensive ones since then and they do the same thing, I can't fathom it, because there seem to be people who have got bluetooth adapter/Torque on Droid working on '96 850s, so it's got to be something my end rather than the ECU itself simply being incompatible...?
    *Edit*
    Oh! SUDDENLY, SIGNATURE!
    ______________
    Vard.
    2003 Volvo C70 2.4T GT
    2000 Range Rover P38 4.6 Vogue
    1993 Rover 820 Vitesse Fastback
    2020 Yamaha MT-10 Tourer Edition
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    As far as I'm aware, the service light can only be turned off with a Draper 69007, or similar, unfortunately Draper have discontinued it, so you need to find someone to where you are who has one.
  5. The Following User Says Thank You to stribo For This Useful Post:
    Vard66 (Sunday 5th January 2014)
  6. #5
    Member
    Oct 2013
    Blackpool
    1
    If you have access to another younger car post 2000 petrol engine try the adapter on that, if it works the issue is the 850 not being OBD-II compliant, just because it has the OBD-II socket means very little - Mike
  7. The Following User Says Thank You to mikealder For This Useful Post:
    960kg (Sunday 5th January 2014)
  8. #6
    Jul 2011
    Poole, Dorset
    6,548
    have you paired and saved it to your phone? (not just connected) it needs to be paired and disconnected before you start torque. is it the full version of the software or the free demo? the demo can play up.
    I'm using the cheapest adaptor on the market with no problems.
    the first connection always takes a while, you'll see the adaptor logo flash fir a bit (on the torque screen) then the car logo will flash for a few minutes before it all sorts itself out.
    310.2bhp / 333ft/lb
    SOLD
  9. #7
    Member
    Rover Turbo Nutter
    Vard66's Avatar
    Jan 2014
    11
    Screwed on that one anyway then. I've got her booked into Johnson's Volvo in Swindon on Tuesday for a code reading/wipe & service light wipe, as I was going in to get a spare key cut and programmed anyway, and it turned out the other day that a friend of mine has wound up managing the parts dept. in there so I get reasonable prices on most things. But I want to be able to diagnose anything that comes up in the future so it's still worth me trying to figure this out tbh.
    ______________
    Vard.
  10. #8
    Member
    Rover Turbo Nutter
    Vard66's Avatar
    Jan 2014
    11
    I've connected and paired the adapter and set it as preferred connection.
    Full software, I did download the beta to have a quick look but was convinced within a couple of minutes it was worth a couple of quid lol.
    ______________
    Vard.
  11. #9
    Jul 2011
    Poole, Dorset
    6,548
    you need to make sure the phone isn't connected to the adaptor before you open torque.
    after that, I can't think of any reason for it not to work.
    does torque say it's found the adaptor?
    310.2bhp / 333ft/lb
    SOLD
  12. #10
    Member
    Rover Turbo Nutter
    Vard66's Avatar
    Jan 2014
    11
    Isn't connected? Usually I plug in the adapter before even switching on Bluetooth on my phone, so no way it could be connected there tbh.
    It does, Torque finds the adapter dandy and pairs fine, just won't communicate with the ECU.
    ______________
    Vard.
  13. #11
    Jul 2011
    Poole, Dorset
    6,548
    I mean connected to the phone...
    plug adaptor into the car, don't allow the phone to connect to it until torque starts, it should connect automatically.
    if the adaptor logo is solid, not flashing, it means it's connected to the torque app. the car logo will then flash untill it connects to the ecu.
    310.2bhp / 333ft/lb
    SOLD
  14. #12
    Driving Miss Daisy
    V70 Graham's Avatar
    Feb 2012
    West London
    2,909
    I used the Wi-Fi version of dongle which seems to connect just fine to my iPhone 5.
    Saying that I have recently bought a cheapish code reader which I am impressed with, I will do a review if I ever get the car back from the garage !
  15. #13
    trying hard to look busy!
    jdavis's Avatar
    Dec 2008
    Doncaster, South Yorkshire
    1,050
    i'm not sure that a '96 850 will be OBD 2 compliant
    It's a 5 Cylinder Orchestra!
  16. The Following User Says Thank You to jdavis For This Useful Post:
    claymore (Sunday 5th January 2014)
  17. #14
    5 pot heart of a Volvo
    T5frankie's Avatar
    Apr 2006
    On the strip
    4,423
    mate obd2 doesnt work on 850's and even some early x70's
  18. The Following User Says Thank You to T5frankie For This Useful Post:
  19. #15
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,385
    I can't believe it took 13 posts to tell OP that 850's arnt obd11
    PIC][/SIGPIC]
    aaaaaaaaaaaaaaaaaaaaaaaaa
  20. The Following 4 Users Say Thank You to claymore For This Useful Post:
    Dangerous Dave (Sunday 5th January 2014),jdavis (Wednesday 8th January 2014),T5frankie (Sunday 5th January 2014),Vard66 (Monday 6th January 2014)
  21. #16
    T5frankie's Avatar
    Apr 2006
    On the strip
    4,423
    Quote Originally Posted by claymore View Post
    lol i know i was thinking the same
  22. #17
    New Identity
    Dangerous Dave's Avatar
    Dec 2006
    West Midlands
    2,491
    The only 850 it will work on is the 850 AWD as that has the Motronic 4.4 ecu in it.
  23. #18
    T5frankie's Avatar
    Apr 2006
    On the strip
    4,423
    Quote Originally Posted by Dangerous Dave View Post
    my missus first s70 t5 wouldnt work it either
  24. #19
    New Identity
    Dec 2006
    West Midlands
    2,491
    Quote Originally Posted by T5frankie View Post
    Hmmm, odd eh?
  25. #20
    Member
    Rover Turbo Nutter
    Vard66's Avatar
    Jan 2014
    11
    Well..... balls.
    ______________
    Vard.
