LiamT4 (Sunday 29th December 2013)
Stolen from the internet:
"It is appreciated that the deposition of liquid gasoline on the wall of the cylinder liner is known to be detrimental to the life of an SI engine. Liquid fuel on the combustion chamber and cylinder liner surfaces may lead to an increase in hydrocarbon emissions, particularly during cold-start operation. In addition, liquid fuel on the cylinder bore may wash the protective oil film from the surface liner, making it vulnerable to increased wear and chemical attack by the corrosive combustion chamber products (the latter particularly true when the liner surface is still cold, promoting the condensation of acids). Finally, liquid fuel on the cylinder wall may pass the piston rings, particularly when clearances are at their largest, causing high rates of 'lost fuel' to the crankcase and dilution of the crankcase oil."
At what AFRs bore wash becomes a problem, I don't know?? but hitting 9's can't be good.
Factory White 855R : 2.5 Bottom End : Ported & Flowed Cylinder Head : TD04 19T TurboVXR Injectors : ME7 Manifold : TWR Throttle Body : Blackbeast IC : AEM Progressive WI : Ferrita 3" DownpipeMilltek Cat-Back : BC BR Coilovers : IPD ARB : AP Racing Brakes : M56 & Gripper LSD
It is a joke. It's so frustrating. The forum should pick a dyno manufacturer, and that be the only figure's that count!!
I will say, that my ATR was dyno'd on the Maha at Marlin when it was completely standard, and it came out at 211bhp. Also a standard S60R (I can't remember who's!) was run on the same dyno and came out at 280 something bhp, which is about right for a standard S60R.
My personal take on it, is that whp is bogus, as so many dyno's produce wildly different figures. But let's not start this debate again!!
The other thing to consider is this time of year, when it's colder outside, the p1's do run a little leaner. They're not clever like the ME7 at adjusting the fueling to keep the desired air fuel ratio. In the height of summer it would run even richer. That's why, when these early cars are being tuned, you want to aim for afr's of mid 11's so you have a bit of scope either way.
After my HLM/melted pistons ££££ up, I was paranoid about afr's. Which is the only problem when you fit a wideband afr gauge, you'll find yourself constantly watching it!
if the drag losses were only 15% that would equate to 331bhp
Ah yes, but on which dyno?!!!
With the right setup, I have no doubt that the hardware you've got should comfortably produce 330-350bhp. With a ported and flowed cylinder head & WI, and tuning to suit you could probably add another 20bhp to that. It'd be a very similar set up to what Redbrick is running.
331bhp, 225whp
But the boost was doing funny things if you remember, it was fluctuating up and down on the dyno, something it didn't do on the road. It was only running 1.2bar of boost, as I was fed up with going through KKK's. It did 60-100 in 6.x seconds, so around 330bhp was probably about right.
