Just been looking on PFV different shocks etc.To replace the nivomats apart from a shock absorber and spring do I need anything else?Any experience with these anyone?
http://www.partsforvolvosonline.com/...oducts_id=7668
James T5 fitted them with good results if i remember rightly
Is the plod height ribbing getting to you already?
It's a 5 Cylinder Orchestra!
you can use the nivomat mounts with standard shocks so no mate. all you need is springs and shocks (from a unimog)
310.2bhp / 333ft/lb
SOLD
Got an old discovery now.
Kingsford G (Sunday 8th December 2013)
ive got two rear shocks you can have. im changing all my suspension and steering soon
The PFV lowering kit is good value for money!
Kingsford G (Sunday 8th December 2013),partsforvolvos.com (Tuesday 10th December 2013)
Best advice is use the best quality you can afford to and do it fast because no one likes a V70 with XC90 rear ride height, before you know it the local estate agent will be offering to help rent out the space in your wheel arches to families on a budget
there are different oe part numbers for the rear shock top mounts. the nivomat ones are wider with a rubber insert.
a bit like the difference between the p1 v70/850 shock mounts.
if martin said they were ok, then you should be alright though.
Perfect fit mate.
From what I can work out, the dome at the top of the OE shock is slightly smaller than the NIV but I'm talking a mm or two. I've had no movement or noises from them as yet and it's been a year.
I know you can't use nivs on standard mounts as it'll ram the mount through the floor with the extra load.
310.2bhp / 333ft/lb
SOLD
kingsford, strongly consider fitting bilstein b4 with the lesjofors lowering springs . I really should make up a kit for this but not enough time, and at our price the set of 4 bilsteins is a steal......
