Plugged my car into diagnostics today and got the following DTC fault codes:
ABS-00A2 Side accelerometer Faulty - known fault (suspect ABS module)
ABS-00A3 Side accelerometer Signal outside its permitted range - known fault (suspect ABS module)
CCM-0021 Air quality sensor Internal fault - known fault
CEM-6A01 Door unlocked, left rear Signal too high - kids messing with doors
CEM-6A02 Door unlocked, right rear Signal too high - kids messing with doors
ECM-1600 Boost pressure sensor - Signal too low - Suspect boost pressure sensor
ECM-170F Boost pressure sensor - Faulty signal - Suspect boost pressure sensor
ECM-261A Long-term fuel trim, bank 1 - Upper limit - Suspect first lambda sensor
ECM-262A Long-term fuel trim, bank 1 - Lower limit - Suspect first lambda sensor
ECM-644A Camshaft control - Faulty signal - Suspect VVT solenoid
What are your thoughts please guys?
