Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
Thread: HU-850 stereo?
  1. #21
    More cars than a Showroom
    volvokid's Avatar
    Jul 2008
    Cruden Bay (Scotland)
    1,464
    Thank you, I will need to buy an ipod, mine got wrecked in the crash lol.
    Martyn
  2. #22
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Quote Originally Posted by volvokid View Post
    I don't think so ,it can I think use a USB lead from a Android phone.
    Have a look on there web site.
    http://www.gromaudio.com/store/usb_a...b2p-vol01.html
    I just don't know what unit is fitted in the car yet.
  3. #23
    volvokid's Avatar
    Jul 2008
    1,464
    It says ipod as well..... But it does seem to be highlighting android more.
    Martyn
  4. #24
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    At the moment it got a iPhone plug lead 4S type not the new 5 plug.
  5. #25
    volvokid's Avatar
    Jul 2008
    1,464
    Im not sure if the new ipods take the lightning connector. If they do I will try it out on the ipad first because I know how fussy apple can be with none genuine parts.
    Martyn
  6. #26
    All work and no play makes
    Jack a dull boy
    Jul 2012
    North Yorkshire
    88
    You are not stuck with single DIN if you swap to aftermarket.
    Get a fascia adapter and stick a double DIN unit in there.
    My HU850 is behaving perfectly (7 years old) even the 6 disc changer works perfectly.
    I`ve fitted a GROM to mine for iPOD connectivity and I prefer my dash to look stock but a double DIN is an easy swap.
    As MRP says, look on EBay and you`ll quickly find a suitable adapter, you will also need a wiring harness adapter to connect an aftermarket unit and MAY lose the steering wheel controls depending on the type of install you go for.
  7. #27
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    The headunit in the R works perfectly, and has a imiv and Nokia handsfree kit connected to it, so is good all round. The headunit in the C70 however is hit and miss whether it'll play a CD or not, luckily I mostly listen to the radio for which it's fine.
  8. #28
    Junior Member
    Jun 2012
    0
    Hi there. These guys are quite good.
    http://www.centralservicescaraudio.c...igation-repair
    Martin
  9. #29
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,548
    Cheap lens cleaner off the market mate - run it 5 or 6 times.
    310.2bhp / 333ft/lb
    SOLD
    Got an old discovery now.
  10. The Following User Says Thank You to M-R-P For This Useful Post:
    stribo (Sunday 16th February 2014)
  11. #30
    Unbannable
    Jun 2012
    7
    I can say I like the IMIV kit I have it in my S60 very neat install and love that I can play stuff through the sat nav screen. Reason I went with tthe IMIV is because my Sat nav DVD drive laser is broke, I was quoted £180 to fix it, but read about the IMIV and thought I may as well get that for 200 and then stick my iphone satnav through the screen. When I got it, I couldnt do what I wanted because iphones crappy software wont just display anythin you want so off I went to jail break my iphone now I can have anything up on the screen and also got a screen friendly notifications centre for texts and such, not that I text back while driving of course.
  12. #31
    volvokid's Avatar
    Jul 2008
    1,464
    Ok so the radio signal WAS rubbish in the S60, I've found that the signal is pathetic when I plug my phone into the fag lighter.
    I decided to pull the plugs out the V70's dvd player and voilà I now have a perfect signal in the car! What causes this then? Im glad I've found the kinda cause to the issue but I want to resolve it now.
    Martyn
  13. #32
    Kawasaki T5. Built by a Swede,
    Driven by a turnip!
    T5RatherAmusin's Avatar
    May 2013
    SW Wales
    303
    Just curious. If you go in your boot. open the side panel on driver side then look down into the well. The aerial is in the bumper how does you connection look?
  14. #33
    volvokid's Avatar
    Jul 2008
    1,464
    I've never personaly checked any connections but strathmore and mrg checked them all and they where fine.
    Martyn
  15. #34
    Norfolk born and bred.
    Give me a high 6!!!
    silverhorse's Avatar
    Oct 2012
    Great Moulton Norfolk NR15
    221
    When you buy a TV or DVD or soundbar, etc for your house, the leads come with an anti interference magnet that you clip around them which insulates the surrounding equipment from any electrical interference which distorts the digital signals.
    Sounds a bit like your problem maybe???
    Me: 2005 V70 2.4 T5 SE. All standard.
    The Wife: 2008 C70 2.5 T5 SE. All standard.
  16. #35
    a 19t just isn't laggy enough
    p fandango's Avatar
    Aug 2004
    4,216
    Quote Originally Posted by Fubar1977 View Post
    the double din fascia is Volvo only, but i agree i went for aftermarket instead of being stuck with Volvo's own
  17. #36
    Wiping smiles off faces!
    Dec 2013
    Portsmouth
    87
    Aftermarket is a whole lot better anyway
  18. #37
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    If you want I can stick it in the post to you to have a play with it. After I have removed it next week with any luck.
    Have now got it removed,was going to fit to S60R but thats gone.
    Do you still want to try it ?.
