Nice work Steve,car looks in good nick
Have you sold the "R" or wrapped it round a tree?
2005 S60 T5 SE X PLOD RICA 300 MAP
Personally I would be concentrating on the low oil pressure. You now have a working roof but you could have ££££ed engine.
Yes, but now the roof's up I've got the garage back.
But the first thing you should have done when you got the car was to look at the oil pressure problem.
I couldn't, the roof was stuck down, and as Rachel works weekends now I don't get a lot of time.
I'll put my disc cutter away for the time being
stribo (Sunday 24th November 2013)
If you are after any cream coloured trim panels then I know where they are 2 ME7 C70`s in a breakers at Emsworth
stribo (Tuesday 26th November 2013)
Right got a bit of time on the C70 today, first off I changed the coilpacks, with nice new ones:
The plastic piping around the wires has gone brittle, and is breaking up, is it worth wrapping them in insulation tape, or will they be o.k. left as is?
Second job was to adapt the boost hoses to bypass the intercooler to see if that was the cause of the boost leak:
Took the car for a spin, but there is still no boost. I'm guessing the turbo's goosed, as when I got back the pipe across the top of the engine was still cold, it also started making a screeching noise from the back of the engine as I was near home:
So when I get time I'll take the inlet hose off and see if there's any movement in the turbo or if it's seized.
And Rob, the oil pressure problem will be checked when the oil pressure sensor arrives from JT, but the light hardly came on today.
stribo (Saturday 7th December 2013)
For the wiring to the coil packs get some new "split convoluted conduit" from the "bay" and replace it all, one it will look neater and secondly it will reduce the chances of bits of plastic dropping down the coil pack holes when you change the spark plugs.
As for your lack of boost are all the small vac lines connected, un-split and more importantly connected in the correct way, I would be checking the simple stuff such as this before assuming the turbo is goosed, also have a good look at the intercooler, is that holed or split, you won't get the turbo to spin up much with the car sat still but it is worth pulling the pipe of the turbos inlet and ensuring it can spin freely by hand.
For the oil pressure, I would replace the simple switch with a pressure sender then read the pressure on a gauge this lets you see what is going on with the oil pressure across a range of engine temperatures and revs, you can get sender units that act as dual function i.e. they provide a low pressure switch and give out an oil pressure signal for the gauge, this would be my first task on this engine before doing anything else as it could prove costly to fix if the oil pressure is as low as the light leads you to believe - Mike
I think the oil pressure problem is nothing compared to the possible goosed turbo.
I'll warm the disc cutter up
is that a d5 or a t5? i wouldnt be reving it or driving it. you can clearly hear theres a oil pressure issue. i bet the cams are now in poor condition. if it was mine. id rip the engine out and buy a new lump with turbo. i bet the turbo is either very worn or siezed due to lack of oil pressure.
isn`t the spare turbo meant to go on the gay gold c70 ??
That screeching sounds like a pully?
Back with a 1997 S70 T5 SE
