It will only use 1 engine for the mot. As far as Iva test goes, as Im using all volvo parts the only points I've used is cutting the monocoque.
PIC][/SIGPIC]
aaaaaaaaaaaaaaaaaaaaaaaaa
merc85 (Thursday 31st July 2014),partsforvolvos.com (Friday 1st August 2014)
PIC][/SIGPIC]
Biff (Friday 1st August 2014),Doingitsideways (Friday 1st August 2014),Jamest5r (Friday 1st August 2014),jdavis (Friday 1st August 2014),JT (Friday 1st August 2014),MoleT-5R (Saturday 2nd August 2014),smithy (Saturday 2nd August 2014),stephenevans99 (Saturday 2nd August 2014),stribo (Friday 1st August 2014),t5 pete (Friday 1st August 2014),Tomcat (Friday 1st August 2014),V70 Graham (Friday 1st August 2014)
I think you can safely take the spacers off the wheels mate.
It's a 5 Cylinder Orchestra!
PIC][/SIGPIC]
It looks awesome Colin.
Will it pass MOT with wheels stuck out that far?
PIC][/SIGPIC]
Ahhhh my bad.
Great progress Colin, when's it going to be ready for a shakedown?
PIC][/SIGPIC]
Certainly coming along now Colin, look forward to seeing this monster in action at some point.
Previous cars:
claymore (Friday 1st August 2014)
looking good colin shows up the one thing i dislike on the 850 the wheel track width difference on the front and rear of one
1995 854 t5r
how do you plan to run the coolant & IC for the 2nd engine - are you utilising the rear windows like the volvaxo?
Volvo ABS ECU Repair
Roof scoop
310.2bhp / 333ft/lb
SOLD
Got an old discovery now.
Hopefully the rad and intercooler will sit at an angle in front of the engine and behind the front seats, air will then be ducted out through the rear passenger window.
roof scoop will be used to duct air into the turbo to supercharger intercooler which will be mounted onto the inside of the roof, if that makes sense.
PIC][/SIGPIC]
claymore (Sunday 3rd August 2014)
As you need 8 points or higher, do you not lose points for your rear suspension by going Macpherson at the rear as well. (it may be Volvo 850 front suspension but it's not originally in the rear) TBH I can't see how the rear axle is the same either? other than you still have two I guess?
Points
Chassis, monocoque bodyshell (body and chassis as one unit) or frame - original or new and unmodified (direct from manufacturer) 5
Suspension (front and back) - original 2
Axles (both) - original 2
Transmission - original 2
Steering assembly - original 2
Engine - original 1
I wouldn't be surprised if it has to have a Q plate, I know you've only used the front engine part of the other vehicle but it doesn't specify 50% of each to be classed as a cut n shut.
Hope this doesn't come across a criticism, if what you've done is acceptable then I have no worries about my V40.Get a ‘Q’ registration number as there is definite evidence of two cars being welded together,
You won’t be able to keep your vehicle’s original registration number if 1 of the following applies:
it has fewer than 8 points
it has a second-hand or altered chassis, monocoque bodyshell or frame
there’s evidence that 2 vehicles have been welded together to form 1 (ie ‘cut and shut’)
Your vehicle must pass the relevant type approval test to get a ‘Q’ prefix registration number.
claymore (Saturday 2nd August 2014),p fandango (Saturday 2nd August 2014)
TBH, I have absolutely no worries about it going for an IVA test and getting a Q plate, that has always been on the cards
PIC][/SIGPIC]
FIREBOLT (Saturday 2nd August 2014)
It shouldnt get a Q plate as it already has a registration, I thought Q plates where only used when the majority of the parts on the car have come from several different vehicles and there is no original registration to base it on?.. ie. kit cars.. As yours is already registered you should be able to keep your current reg... Shouldn't you?
Previous cars:
Is the Volvaxo a Q plate? if it isn't, then I can't see that yours would be, as you haven't altered yours as much.
PIC][/SIGPIC]
