Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: ABS/trac. fault
    Leeds_finest's Avatar
    Dec 2011
    Walsall
    137
    ABS/trac. fault
    As some of you may know, I have had an ABS/TC fault since I bought my car - the ABS an TC don't work at all.
    I don't have any ABS warning lights on my dash and the fuse in the engine fuse box looks fine. Also no DTC's on the OBD2 last time it went to Volvo.
    My questions are:
    1. Does the P2 have an ABS light?
    2. I'll be testing as much as possible tomorrow, I guess I need to test the system and sensors via the pins on the ABS module plug?
    Interesting that as I read over the online MOT history, it failed in April last year on an ABS warning. When I bought it in November last year the car came with 12 months and no warning lights on dash. If there is an ABS light, maybe they removed the bulb instead of fixing the issue? When I switch the ignition key over there are also no ABS lights even illuminated for a second or two.
    Sorry, nothing Swedish here...
    Junior Member
    kwk's Avatar
    May 2011
    Neath
    4
    Yes it should have an ABS light. I think that would have been an advisory last year but a failure now.
    Dec 2011
    Walsall
    137
    Just read over my paperwork and actually, when it last went into Volvo:
    ABS-0070 Pump motor Faulty signal. DTC is found active.
    So does this automatically suggest the PUMP is shot? Or could it still be a wheel sensor?
    Dec 2011
    Walsall
    137
    Quote Originally Posted by kwk View Post
    So where are they? Bottom right hand side where the battery/EML are etc?
  5. #5
    Junior Member
    kwk's Avatar
    May 2011
    Neath
    4
    Yes, next to the EML.
  6. #6
    Dec 2011
    Walsall
    137
    Mine definitely doesn't have one so i'm guessing the swines I bought the car from removed the bulb?
    Anyway - has anyone else experienced the ABS 0070 fault? Was it new pump time?
  7. #7
    Junior Member
    kwk's Avatar
    May 2011
    Neath
    4
    Should have added that I took one of my S60's on a 3000 mile Euro tour in the summer and the tracs/ABS warning was on and off for the whole trip. A faulty reluctor ring was diagnosed but I have not yet changed it as it has not come on since returning home and the car passed the mot last month.
  8. #8
    Dec 2011
    Walsall
    137
    Ahhh that's interesting - what's a reluctor ring and how can I check it?
  9. #9
    Dec 2011
    Walsall
    137
    The ring on the hub/shaft - i'm with you now.
    I'm fairly certain ABS 0070 is a pump code though
  10. #10
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,548
    The bulb cannot be removed from the DIM mate.
    The reluctor ring is a cogged ring that sits around the outer cv joint. It hides inside the hub and the abs sensor picks up it's readings from it.
    310.2bhp / 333ft/lb
    SOLD
    Got an old discovery now.
  11. #11
    Dec 2011
    Walsall
    137
    Hmmmm that's an odd one then. I definitely have no ABS warning light show up with the other warning lights when I flick the key to position 2. Nor do I have one come up when cranking or running the engine.
    However, 0070 is present and I have no tracs or ABS.
    If I need a new module - is it a BBA REMAN job? I imagine a dealer costs a fortune.
    KWK - was your reluctor ring clearly damaged in some way? I.e. was it a visible fault?
  12. #12
    Junior Member
    kwk's Avatar
    May 2011
    Neath
    4
    It's a very small crack and is still there.
  13. #13
    Junior Member
    kwk's Avatar
    May 2011
    Neath
    4
    Oh and very rusty.
  14. #14
    Jul 2011
    Poole, Dorset
    6,548
    Basically, there's raised parts of the ring that the sensor picks up. a crack can make the ring slip or wobble. this then reads as a rpm mismatch against the other wheels and upsets the tracs system and abs system.
    If the pump has gone, another one from a scrappy may solve it but you might need to use the electrical half from your old unit to make it work,
    You have pretty piss-poor luck with these cars mate. Ever thought of riding a bike? lol.
    310.2bhp / 333ft/lb
    SOLD
  15. #15
    Dec 2011
    Walsall
    137
    KWK have you got any codes stored?
    Mart I have a feeling, from what I've read, it's not the pump that fails as such it's the module itself, may be soldered points inside? Not sure I fancy a second hand part if it's a common fault
    I have considered riding a pony but they use too much grass... And carrots.
  16. #16
    Junior Member
    kwk's Avatar
    May 2011
    Neath
    4
    No to the codes. The garage only found the fault because they replaced all the brakes before I left and thought it was something they had done. It was a visual examination and they would have replaced the ring at the same time but, they didn't have one and I needed the car urgently.
    It's strange that it hasn't come back on but it will.
  17. #17
    Dec 2011
    Walsall
    137
    I'll check the rings then.
    Sadly, I have a bad feeling it will be a bad module though as I think a bad ring would flag up individual ABS sensor faults (or none in your case).
  18. #18
    Dec 2011
    Walsall
    137
    Right,
    Done some digging. Found out that the ABS fuses are ok, and the fuses to the instrument cluster are ok too. Tested ABS sensors and all are reading fine.
    Removed cluster and the two grey bulbs for the left display are missing!! Furthermore, the ABS and TC bulbs have been taped over!!!
    Some people should be put behind bars.
    Moving forward, my mate narrowed the fault to either:
    1. The wire between the ECU and ABS module.
    2. The ABS module itself.
    Going to check the wiring etc next time and hopefully if it's the module we will try and solder any dry joints.
  19. #19
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    The mot tester should have a bit of info on any car they are about to test,with regards what lights light and for how long they come on for to stop this type of thing from going on.
  20. #20
    Dec 2011
    Walsall
    137
    Well what's happened, it seems to me, the garage failed the MOT because of the ABS Fault. Then, in order to get it through the MOT and sell the car they have done these horrendous, dangerous cover ups.
    It's the same garage that failed, then passed then sold the car to me.
