My rant isnt that bad really, its just kinda p*ssin me off a bit
When a got ma car the lamnda light was on
A was told it was a lambda sensor on the exhaust was the problem
A had the codes read and there were around 4 codes came up but never noted them we just reset the light to see what happened
Light came back on and as times went on and recently started cutting out now n then and a was thinking MAF....
When ma dood checked the codes it said something like lambda sensor/air leak, Wooohooo the rubber elbow was burst That was fixed yesterday and the light had went out anyway so happy days
An hour after leaving the garage lights back on and the cars cutting out again (mainly when been run a wee while and well heated up)
Went back in this morning and its showing.....
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
and
P0243 Turbocharger Wastegate Solenoid A Malfunction
As the codes werent cleared yesterday am thinking that the 107 was still there from the rubber elbow as this is on the maniford and its to do with pressure but a could be wrong!
Could you guys n gals with all your knowlege help lil old me out once again??
Cheers in advance luv yeez aw
