Hey going to make a start on modding my s60 2.4t runs at 200bhp the car is totally standard atm,
Going to set a budget of 500 pm for buying things what would you recommend buying first? And why?
Cheers in advance
Cheers in advance
Also would be grateful for links to parts etc as this is my first project and still a bit of a noob,
exhaust, cone filter remap.
Rnash2002 (Monday 21st October 2013)
I've started from the outside and worked my way to the remap..
i.e. sort the suspension (shocks, springs, bushes)
Brakes (bigger/better, dot 5.1 fluid)
stage zero tune up (all fluids, all filters, clean or replace injectors)
new hoses (upgrade boost hoses, Vac hoses, tcv,)
Then look at exhaust and downpipe
bigger turbo?
then get a custom map to suit all your mods.
Don't overlook the suspension and brakes, there's no point making it go fast if it can't put it down or get you round the twisties without climbing a tree!
310.2bhp / 333ft/lb
SOLD
Got an old discovery now.
hybriduno (Monday 21st October 2013)
meh
310.2bhp / 333ft/lb
SOLD
k24 and s60r manifold, xorst, map, jectors, facelift t5/R induction
Cheers any links to a decat pipe?
graemewelch (Monday 21st October 2013)
Not yet, got the DP to fit to the R as well.
As smithy has said, you can run a K24 but you will also need to get green injectors and a custom remap. Alternatively you could run a 16T with white/blue injectors wind the boost up to 9.5psi and run standardish T5 power without a remap. Altho you would be better off getting a remap for the changes and maximum benefit.
I have run mine for over 2 years without a remap with no problems too speak off.
P1 V70 2.5T Scorpion Exhaust, 3" downpipe 100cel cat, BSR induction, KKK24, GWE 3" Maf to turbo pipe,japanifold , 2010 V50 T5 Alloys Projector Headlamps with 5k Hid kit Quickshift kit, strut brace, Koni Yellow Sport,IPD BCS AET motorsport remap
Previous: 2004 XC90 T6, 240GLT Estate, 343DL
Toys: Capri 3.7 Twin turbo, Kawasaki ZX10R 2006,
