Page 9 of 30 FirstFirst ... 789101119 ... LastLast
Results 161 to 180 of 595
  1. #161
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Quote Originally Posted by volvokid View Post
    That's very cool
    just had a play with camera plugged into the TV at home nice clear picture even got the green,amber,red lines and STOP on screen so it's a PAL camera they sent,so should work in the car even the image is flipped over so looking good so far.
  2. #162
    ...here we go again...
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    I want one.....Link please!?
  3. #163
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Quote Originally Posted by LeeT5 View Post
    Lee just to say still not fitted to car,and it will need to be trimmed by 1mm or so not 100% sure it will work well.
    www.ebay.co.uk/itm/321033865527
  4. #164
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    That's the dress up kit, same as what I got minus the oil filler cap.
    What was the carriage costs mate and what did u have to pay in import tax? Did you have to collect or was it posted to your door?
    Well the import paperwork turned up today and it was £25.
  5. The Following User Says Thank You to Harvey For This Useful Post:
    LeeT5 (Friday 23rd May 2014)
  6. #165
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Little bit of up date.
    Brake discs fitted.
    Aux belt & tensioner fitted.
    Then the best bit MOT done and passed with no advisory notes at well.
  7. #166
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Today as the weather was just crap went from these to.
    Winters 17"
    Summers 18"
    The summer tires are an awful lot quieter from road noise as well.
  8. #167
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,548
    Good news with the mot mate but you do always keep the car well.
    310.2bhp / 333ft/lb
    SOLD
    Got an old discovery now.
  9. #168
    Driving Miss Daisy
    V70 Graham's Avatar
    Feb 2012
    West London
    2,909
    Can't believe I missed the MOT, well done on the pass mate.
  10. #169
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Well today rear disks & pads went on with new handbrake shoes,and a spring kit as well also fitted the manual adjusters which makes a big difference to set up very easy,
    The car no longer rolls back when they handbrake is pulled on.
    Also the little pig tail springs were beyond use trying to get the old discs off they got pulled out of shape.
    Old shoes were at the end of there lift as the friction material was coming away.
    The new adjusters spot-on.
    The new drilled disks look the part but did have to give the a coat of paint as they were very dark gray almost black.
    The next problem is it now needs new handbrake cables as the o/s one is not as smooth as it should be to release,but working fine.
    Looks a real pain to change them
  11. The Following 2 Users Say Thank You to Harvey For This Useful Post:
    LeeT5 (Sunday 6th July 2014),silverhorse (Sunday 6th July 2014)
  12. #170
    Norfolk born and bred.
    Give me a high 6!!!
    silverhorse's Avatar
    Oct 2012
    Great Moulton Norfolk NR15
    221
    I have got a rattly n/s handbrake shoe assembly and it drives me mad. Have just bought some of those pig tail springs to try and tighten everything up.
    Looking at the equaliser bar where the handbrake cable divides under the centre console, the left cable looks to have stretched. Oh joy............... You are right, looks like a pig of a job. Will be interested to see how you get on.
    Me: 2005 V70 2.4 T5 SE. All standard.
    The Wife: 2008 C70 2.5 T5 SE. All standard.
  13. #171
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Didn't know there was a manual adjuster! Is is a mod or choice for the R models?
  14. #172
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Yes it's a mod sort of but it's a Volvo mod here's a Volvo parts drawing.
    Removed item no 15 then fitted 17 & 18 now the car doesn't roll back a couple inches before it locks on.
  15. The Following User Says Thank You to Harvey For This Useful Post:
    LeeT5 (Friday 29th August 2014)
  16. #173
    Member
    Mar 2010
    0
    Harvey, you don't happen to have the part numbers for 17 & 18 handy do you?
    Rear brakes are going to get done soon and it seems like a good idea to fit these at the time
  17. #174
    Member
    faRRow85's Avatar
    May 2014
    burton in kendal
    14
    Youre caR is pretty damn fine.it makes me want to trade in the s60 for a v70.
  18. The Following User Says Thank You to faRRow85 For This Useful Post:
    Harvey (Saturday 12th July 2014)
  19. #175
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Quote Originally Posted by SomeBloke View Post
    17 & 18 part numbers are 30793438 for the claw and 30793437 for the adjusting link.
  20. #176
    May 2010
    manchester
    85
    Lovely car and mods you have there,, was the exhaust a straight swap from the s60 or did it need modifying to fit your car,
  21. The Following User Says Thank You to Craigy t5 For This Useful Post:
  22. #177
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Quote Originally Posted by Craigy t5 View Post
    The TME exhaust is telescopic so it adjusts to both cars the V70 is approx 3" longer than the S60.
  23. The Following User Says Thank You to Harvey For This Useful Post:
    Craigy t5 (Friday 11th July 2014)
  24. #178
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    At long last theses turned up after 3 weeks..
    Wastegate setting tool.
    Door pins set.
  25. #179
    855r 6sp lives
    Ettienne's Avatar
    Jun 2014
    Waterlooville
    517
    I had the ipd gauge they seem pretty accurate.
    I'll be looking at my rear brakes, although they look new, I'll check the handbrake shoes just incase, I have seen these things separate and smash up the rear of the car. I think I have 2 spare rear uprights.
    I'll follow your adjuster upgrade at same time, nice one.
  26. #180
    Feb 2006
    manchester
    628
    Awesome car
